Question about Plumbing
Remove kitchen faucet model Grohe A112.18.1M - Plumbing
  • 2712 Answers
SOURCE: kitchen faucet Remove
Start by turning off the water supply, either by shutting off the main water supply to your house (probably located close to your water meter), or by closing the shutoff valves on the water supply lines to your faucet. Then, open the tap to allow the water to drain out of the lines and remove any water pressure. Next, use your adjustable wrench and disconnect the hot and cold water supply lines running to the faucet. If you're going to replace the lines, disconnect them at the shutoff valve, but if you're going to reuse the existing lines, do your disconnects at the base of the faucet itself. ow it's time to actually remove that old faucet. Faucets are attached in one of two ways. Bottom mounted faucets are removed from the top of the sink. To remove a bottom mount faucet, you need to take off the faucet handles and escutcheon to get to the nuts holding the faucet. Once the nuts are exposed, use your wrench to take them off. Top mounted faucets, unfortunately, are held in place by nuts located on the underside of the sink. You'll need to get under the sink to remove them, and space may be at a premium. If you're lucky, you'll be able to use your slip joint or locking pliers to loosen the nuts. However, if pipes are in the way, you'll need to use a basin wrench (a wrench specially designed to work in tight spaces where you don't have room to use an ordinary wrench or pliers). Once you've removed the nuts holding the faucet, just lift it up off the sink. If there is some caulking holding the base to the sink, slide the blade of a utility knife carefully around the faucet base to cut it loose. You'll need to remove any old caulking or "grunge" that may have built up around the old faucet. You can get silicon remover at your home store, and a mixture of vinegar and water or an orange cleaner will remove the grunge.
Posted on Aug 27, 2008
SOURCE: grohe ladylux cafe faucet removal
You will need a Grohe Fitting Key to insert into the fixing tube (which is the area after you have removed the Handspray and the Fit spout) and turn counter clock wise. If you don't have Fitting Key, call Grohe at 630-582-7711
Posted on Feb 24, 2009
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
  • 349 Answers
SOURCE: how to remove
http://docs.homeclick.com/PE-Links/Grohe/Grohe-33755-manual.pdf
Check out this link for a manual with instructions for this faucet.
Posted on Jun 10, 2010
Dplumber
  • 119 Answers
SOURCE: How do you remove the handle son a Grohe two-handl...
Pull the handles straight out of the faucet. use both hands to pull back on the hand while wiggling it left and right just a little at a time. Eventually it will pull off.
Posted on Dec 12, 2010
Grohe warranty
GROHE - Warranties - Services for you
https://pro.grohe.com/us/5685/services-for-you/warranties/
  1. Cached
Residential Products: We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing ...
Warranty - Grohe
https://www.grohe.ca/en_ca/our-service/warranty/
  1. Cached
We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing defects in materials ...
Luxury Bathroom Taps, Shower Heads & Kitchen Mixer Taps ' GROHE
  1. Cached
  2. Similar
GROHE - Luxury fittings for exceptional bathrooms and kitchens. Our range of bathroom taps, showers, shower heads and kitchen mixer taps includes designs to suit all interior styles and budgets.
GROHE Faucets Warranty - eFaucets.com
https://www.efaucets.com/grohe-faucets-warranty.asp
  1. Cached
Limited Lifetime Warranty (U.S.A. Only). Residential Products: GROHE provides the following warranties on its products to the original purchaser, installed in a residential application. This warranty is effective for all faucets sold after January 1, 1997.
calling grohe faucet owners..lifetime warranty? - Houzz
https://www.houzz.com/discussions/.../calling-grohe-faucet-ownerslifetime-warranty
  1. Cached
  2. Similar
Nov 11, 2010 - My parents put in a grohe faucet 25 years ago that has been leaking for the better part of the past 15 years. I JUST noticed the name on the faucet as I was sitting at the counter last night and thought, "hey, I bet this expensive faucet has a lifetime warranty" Can anyone share their expe...
Dec 12, 2017 | Grohe Home
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
http://www.doityourself.com/forum/plumbing-piping/310875-low-water-pressure-new-kitchen-faucet.html#b
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
How do you remove the tri handle?
You just pull the handles straight off the faucet. There are no screws or bolts holding the handles. Only a friction guide attached to the faucet stem. You can see this guide in the Grohe Classic Kitchen/Bar Faucet 31.057.000 installation instructions.
Dec 12, 2010 | Grohe Classic Kitchen/Bar Faucet ...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How do you remove the handle son a Grohe two-handle classic style faucet
May 20, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Grohe kitchen faucet burst supply line
With my past experiance with any Grohe product,you will experiance a problem.I have been doing plumbing service work for 20 yrs. and every time I encounter this product,there is always a major problem.I don't know what the big deal is about this product,it cost too much and parts are hard to come by,you must order most of the time.then wait 3 to 4 weeks.hope it's the right part!
Jun 19, 2009 | Plumbing
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
My Grohe Kitchen Fawcett lost water pressure, is their a manual online available?
make sure you check the strainer that unscrews from the spout. SOmetimes these clog from sediment. ALso check the supply valves to the faucet (sometimes there is sediment in these--opening and closing helps) you may have to remove the cartridge(s) depending on you model number. You can probably download the manual at homeappliance.manualsonline.com
Jan 04, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Plumbing Logo
426 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
