My xl24 dimplex storage heater keeps blowing the fuse board
The heater seems to blow the fuse on the fuse board over night. It has worked without problem for the last 5 years. It is an xl24 simplex heater.
tinytrees
  • 92 Answers
SOURCE: pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Posted on Feb 03, 2009
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
SOURCE: Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
It is a problem on your low voltage side. I had the same issue and found that my wire going to my outside condeser had been snagged on a wire hanger in my basement and was shorting out the system. I went a head and replaced the entire wire from my outside unit to my indoor and haven't had an issue since. So my advice is go to HD or Lowes and purchase some 14 gauge wire and replace the low voltage wire. If that doesn't work, then replace the thermistat wire, and thermistat. Great time to upgrate to a energy efficient thermastat.
Posted on Mar 18, 2009
SOURCE: I have two dimplex XLN storage heater, it was
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Posted on Dec 21, 2009
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
Dec 01, 2013 | EDENPURE USA1000 Infrared Heater
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
Hi I have a night store heater model 79168 in my new home and no idea how to use it!! Please help :)
Here is a good article for Dimplex, a storage heater manufacturer, that explains the the theory and how it works. I'm sure you will find it interesting. http://www.dimplex.com/storage_heaters#
Basically, thermal storage heaters heat ceramic bricks during off peak hours (during the night), store the heat to be used during peak hours (during the daylight hours), when electricity is more expensive per kilowatt hour.
Hope this helps you.
Apr 18, 2011 | Heating & Cooling
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
Dec 19, 2009 | Dimplex Heating & Cooling
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
My dimplex night storage heater has stopped working.
Feb 01, 2009 | Dimplex Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
