Question about Kitchen Ranges
I have a Magic Chef Smooth top electric range that is about 14 years old. Model # 3888VVV. F-7 code is being displayed in the clock screen and a constant beeping sound is occuring. What problem does this code refer to?. As far as I can tell, the stove is in working order.
  • 135 Answers
F7 is a bad touchpad. Replace control, part # 12001603. It's about $300 new but there are some used ones on ebay for much less. Hope this helps!
Posted on Jan 20, 2009
Magic Chief "Chateau" double oven,
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Jan 02, 2011 | Magic Chef Kitchen Ranges
F-7 and beeping is occurring on my Magic Chef,
Hi sixgunromeo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 05, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
I can't get my oven to go on, keep getting f-7 code on panel
F7
Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
Apr 11, 2009 | Magic Chef CER3760 Electric Kitchen Range
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
Oven or smooth top will not turn on. breakers are good and it is plugged in.
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Dec 04, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
166 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
