Question about Savin Office Equipment & Supplies
Savin 2535p with SC320 error code
Moved from one location to another and now receive a SC 320 error code when trying to make a copy.
bowdo
  • 78 Answers
SOURCE: LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Savin SC548
Fusing installation error Fusing unit set error.
Turn the copier off.  Remove the fuser unit out of the machine by removing the screw out next to the blue knob and pull it out by the blue know.  Inspect it for wear and tear.  If anything looks worn out it should be replaced.  Reinsert the fusing unit back into the machine.  Secure it with the screw and turn the power on.
Posted on Sep 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Posted on Oct 31, 2008
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Lanier 5518 gives a SC320 error code
This SC-320 code error occurs when polygon mirror motor fails or poor connection between BICU & polygon mirror motor please check first the connector of motor if you feel that the connector is good change the polygon mirroe motor it sits inside the LD unit please call the expert to change the part
thanks
Dec 15, 2010 | Lanier Office Equipment & Supplies
Error code sc320
sc code 320 laser unit faulty polygon motor try lubricate bushing if still codeing out replace polygon
motor
Nov 11, 2010 | Ricoh Aficio MP 1600L Black and White...
Sc320
That is a "Laser motor" Error - Laser motor is dead, and needs replacement
Aug 14, 2009 | Ricoh Aficio 180 Laser Printer
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Functional Problem SC321-00
What is the actual code. Your heading says '321', then you list "320"?
"320" is the polygon (laser motor) that is defective. "321" is more likely the BICU board.
Could simply require the LD pitch adjustment be performed, depending on what else you have done. Do both the 400dpi, and 600 dpi. initial setting
SP 2109-3 (400 DPI)
SP 2109-4 (600 DPI)
Mar 30, 2009 | Ricoh Aficio 450 Copier
47 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
