Question about Aurora Electronics Office Equipment & Supplies
MANUAL AURORA PAPER SHREDDER MODEL as502mx - Aurora Electronics Office Equipment & Supplies
SOURCE: Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Posted on Feb 24, 2008
SOURCE: NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Posted on Mar 22, 2009
  • 537 Answers
SOURCE: I just bought my shredder 3 weeks ago and
Did you open up the shredder or remove it from the basket? Look and see if the switch is in the right place and is not being blocked.
If you didn't mess with the switch and just cleared the jam, then take it back to where you bought it for a replacement
Posted on Apr 17, 2009
  • 19 Answers
SOURCE: Our Aurora AS1712X paper shredder is jammed in a c...
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
Posted on May 30, 2010
  • 22 Answers
SOURCE: I have an Aurora as662c paper shredder, I have a
There are 5 screws that you need to remove, 1 of them is hidden beneath a white sticker that says void warranty if removed.
Posted on Sep 08, 2010
Aurora paper shredder model AU1050XA
Stan Chandler:
First, unplug the shredder. Remove the shredder head from the basket and turn it upside down. You will see the screws on the bottom side of the shredder head.
Feb 23, 2013 | Aurora Electronics Office Equipment &...
Looking for troubleshooting manual for Aurora Paper Shredder AS1015CD.
There is a trouble shooting on their web site for Auror!
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
May 27, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Some dummy (Not THIS one), apparentlly opened this Aurora AS-662-c Paper shredder, couldn't put it back together, so the 'Safety-interlock micro-switch' is properly activated. gave it to me to fix/throw...
They also have trouble shooting on their web site that might help. Hope this help you!
Apr 28, 2011 | Aurora Electronics AS-650C Cross-cut...
Hi, my Aurora AS1002MSB is jammed and it will only go in reverse. Is there any way to fix it?
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck....
Apr 08, 2011 | Aurora Electronics AS1015CD Cross-Cut...
I have an Aurora Shredder -- Model #AS1512X. Paper got jammed and I pulled the paper out and now the shredder will not work. Any ideas as to how to fix this?????
Check safety and detection switches. 1. Safety is on the bottom and left or right side of shredder unit inside a narrow gap. On the bucket's wall there is a natch witch should go into the gap, when you put shredder correctly. Check if switch and natch are on the same side. Simple turning around will solve problem. 2. Check a detection switch. It is located in the middle, inside of gap. This switch engages and turns motor on when you put paper into shredder. In other words sheets of paper should push the switch first before touching shredding rolls. If you have digged out that paper from the top side, chances are you have broken that switch.
Feb 12, 2011 | Aurora Electronics Office Equipment &...
I have an Aurura model A S 860 C paper shredder. It only runs in reverse.? Help
I unplugged it, took out some paper, wiped it down since there was alot of white dust and used my son's air spray can and sprayed both top and bottom of the teeth and away it went again with no more issues so far. If this doesn't work, then I will also do Bernard's fix.
Sep 07, 2010 | Aurora Electronics AURORA - Aurora paper...
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
The shredder will not cut the paper. the motor
I just had this problem. I took the screws out from the bottom of the shredder and opened it up, take a look and see if there are any cracks around the frame that surrounds and holds the shredder in place, if so you have to glue the crack so the frame is stable again.(the crack/break in the frame prevents the paper from cutting because the teeth on the shredder are not fitted properly). hope this helps.
Aug 28, 2009 | Aurora Electronics AURORA - Aurora paper...
BROKEN GEAR
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Dec 31, 2008 | Aurora Electronics Aurora 5 Sheet...
253 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
