LG W 8013F Washing Machine Won't spin!
The machine simply won't spin!!! It gets to the spin cycle then all the temp and spin speed buttons flash!! I've tried putting it on for just a rinse and spin and it does the same thing! Today the pre wash, crease care, time save and rinse buttons are flashing instaed!! We've cleaned out the filter, checked for any blockages and have even turned the machine off at the power pint for a couple of days but nothing has fixed it!!! Any help would be much appreciated!! Thanks!!
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
My washing machine won't go to high speed spin to remove water from clothes.
Possible there is no switching for the cycle from the controller or there is speed limited due to sensor action for vibration. Check the leveling of the machine, if not use rubber footing to hold the machine steady.
Also check the drives for friction , if so reset and lubricate.
Jan 21, 2013 | Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
My Isis 1205 washing machine won't spin and the
chk drive belt or motor to see if working or see if u have a trapped object ?
Mar 11, 2012 | Washing Machines
LG washing machine fail to spin at end of the cycle
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 07, 2011 | Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
Jul 05, 2011 | LG Washing Machines
Lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had a similar problem i unplugged the machine and left it stand for 8 hours .. it works ok..
Apr 22, 2009 | LG WD-16115FD Front Load Washer
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
