Question about Water Heaters
Rheem 41v50 pressure release - Water Heaters
5 Suggested Answers
  • 8404 Answers
SOURCE: We have a 83 Gal. Rheem 41V50 40,000 Btu - What do
Is this unit shared with other households? 83 gallons is a lot.
I would say that a 40 gallon fast recovery gas or electric should take care of the needs of a family of 4 or so.
If you do this, you will notice a big change in your utility bill!
Posted on Oct 20, 2009
  • 553 Answers
SOURCE: I have a rheem 41v50 water heater its leaking out
If the water heater itself is leaking it most likely cannot be repaired. If it's leaking at the presure/temp relief valve it could possibly be dangerous and needs immediate attention. If it's the pipes leading to the water heater then it's most likely worth repairing. If the tank is old and rusty it's best to replace it. If it's fairly new it might still be under a manufactures warantee. The last I knew Rheem had warantees up to 11 years, depending on the model water heater. With out actually looking at the water heater it's almost impossible to give a more definite answer, I hope this helped.
Posted on Mar 28, 2010
  • 349 Answers
If it is leaking out the top it would be best to replace it. just check the fittings and make sure they are not leaking and running in the heater. Try to dry it up as much as possible if it is around any fittings.
But if you can see it's coming from the tank it would be best to replace because it will need replacing later even if it could be plugged temporary now.
Posted on May 18, 2010
  • 48 Answers
SOURCE: Rheem NatGas hot water heater model 41V50,
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Posted on Mar 14, 2011
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
I have Rheem model 41V50 leaking from the top...The top is a lid with screw....can I buy and replace the top ?
No.
Replace tank.
Buy 40 gallon from local Lowes and install yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Under thin metal shell is a welded steel tank, surrounded by insulation and then covered with painted metal shell. The shell is what you look at.
The inside steel tank is made to withstand high pressure expansion that comes with heating water.
The steel tank has rusted out.
Turn gas control valve to vacation, so pilot light stays on, and then only heat enough water as needed until you can replace tank.
Prevent next tank from rusting by replacing anode rod, and ground water pipes.
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheemglas fury model # 41V50 the approx. 5 gal pressure tank above the water heater is corroded and leaking. how difficult to replace and what is the name of the tank
1) If tank is connected with single pipe to cold water line, then it could be expansion tank.
Add a comment with photo so I can see.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Take photo to plumbing supply store.
Expansion tanks unscrew from pipe. Simply install it and it has internal pressure bladder.
Has to install on cold water line.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Model 41V50 Rheem water heater (50 gal. natural gas) and needs to be replaced. However, I can't find this model at any of the local stores. Has this been discontinued? If so, what can I get for a...
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
Jul 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a rheem 41v50 water heater its leaking out of the top is it a major problem or can it be repaired?
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater leaking
Yes, you will need a new heater. The inner tank has rusted thru and it is way cheeper to replace the whole water heater than trying to fix the old one.
Nov 21, 2009 | Rheem 50G Natural Gas Water Heater
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Oct 20, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
54 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
