How to remove bios password?
I forgot my bios password. I can not get into the bios screen.
  • 1,824 Answers
1) Why did you even make a BIOS password?
2) Did you write it somewhere, try finding if you have.
Posted on Jan 08, 2013
sandrew
  • 2961 Answers
SOURCE: Bios password reset
The only way to reset a bios password is to locate either the cmos battery on the motherboard which can be difficult or locate pins CLRCMOS, JBAT1 or similair and short the pins.
Posted on Apr 11, 2007
RALilja
  • 398 Answers
SOURCE: toshiba SPM30 bios password remove
All you need to do is open one of the covers on the backside of the laptop and remove the CMOS battery (it looks like the size of a quarter) for a few seconds, then place it back into it's holder and put the cover back on. You can then power up the laptop and then re-set up all the settings in the BIOS in order for the laptop to work correctly as all previous settings have been forgotten including the password.
Good Luck!
Rich Lilja
Posted on Jan 17, 2009
ODCaloney
  • 260 Answers
SOURCE: bios password
The master password for Compaq is "compaq"
If that doesn't work you need to use a jumpe on the motherboard:
This Jumper is often named like: "RTC_CLEAR" , "CLEAR CMOS" , "CLRCMOS" , "CLRCMS". His position is often near by the motherboard battery. You will need to reconfigure any BIOS changes that you have done.
Posted on Mar 17, 2009
SmartFix
  • 89 Answers
SOURCE: forgot the password of bios of acer aspire 5584 wxmi model: zr1
1. Go and download the bios file - ftp://ftp.work.acer-euro.com/notebook/asp.../bios/v1.06.zip
2. There should be a file call AG1A-106.EXE inside Alviso folder, just extract this file to the location you like.
3. In windows, use cmd (Command Prompt) to run this application.
4. The syntax should be ---- AG1A-106.EXE /ldcmos /reb -----
5. It may take 1 minute to load up, when it appears, just flash it.
6. Computer will restart after flashing and password should be cleared.
7. Don't forget to set back the BIOS settings if required.
Hope this helps!
Please rate my response!!
Posted on Jan 29, 2010
leecom72
  • 4806 Answers
SOURCE: i forgot bios password! I
Removing the RTC battery will not do it.
Laptops these days are very secure. You need to call HP and prove ownership and they will give you a backdoor password.
Regards.
Posted on Oct 20, 2010
Toshiba L850D bios password
If removing CMOS battery did not help, you need to do the BIOS reset from jumper on motherboard.
Apr 22, 2014 | Computers & Internet
Forgot bios password black screen blue box
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware..
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Sep 04, 2012 | Toshiba Satellite C655-s5090
Laptop SONY VAIO VPCEB32FM: how to remove BIOS password
The BIOS password is probably the Power On Password.
This method may not work. Remove the BIOS battery for 20 mins until the charge in the BIOS is depleted. Insert the BIOS battery go into the BIOS setting and set the Date and Time etc.
If this does nor work then the BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work and there is probable no backdoor passwords.
The Sony support maybe able to offer a solution, check the support WEB site..
May 23, 2012 | Sony vaio vpceb32fm/w Notebook
I forgot my password and need help to get it back
Which Password? Bios Password? Hard Drive Password? Windows Welcom Screen Login Password?
Which Operating System?
If it's the BIOS Password you will have to take the laptop apart to get to the CMOS Battery and remove it.
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Apr 07, 2012 | Computers & Internet
I forgot my password on a dell inspiron N5110 laptop
i forgot DELL INSPIRON N5110 ADMIN BIOS PASSWORD......HELP
Jan 19, 2012 | Computers & Internet
IBM T60 Bios password has to remove
The simplest way to remove a BIOS password is to simply remove the CMOS battery
Jun 14, 2011 | Computers & Internet
Forgot password. What F key will get me into Bios
If you forgot the password to the BIOS, then you're likely not going to be able to remove it. If it's just a BIOS password on the hard drive, then you have a chance of being able to reset it. Typically, the HP\Compaq Setup keys are: Esc, F1, or F10. When you first power on the laptop there should be something at the bottom of the screen for a second or 2 that tells you what keys you need to press.
Jul 02, 2010 | HP Pavilion dv9000z Notebook
Password
Some BIOS manufacturers implement a backdoor password.
The backdoor password is a BIOS password that works,
no matter what the user sets the BIOS password to.
These passwords are typically used for testing and maintenance.
Manufacturers typically change the backdoor BIOS passwords from time to time.
BIOS Password Compaq
Dec 19, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
David Payne
David Payne
