Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water Leaking from Freezer Side of Refrigerator
There is water leaking from the freezer side of our model JCD2389GT side by side Jenn Air refrigerator. This happens everyday at about the same time.
  • Ronnie Marden Jun 29, 2007
    Hello There Noggin....
    I replied earlier today but it looks like you didn't get the message..
    We have not fully defrosted the unit recently.
    Operation appears normal..in all aspects.
    Temps OK all around.
    There is water/ice accumulating on botton section of freezer.
    Water appears to be leaking from beneath freezer door gasket.
    All door gaskets appear to be in good order
    We have a swamp cooler that operates 24/7.. so moisture in our home much higher than typical Nevada home.
    Problem started about three weeks ago when outdoor temps went above 100.
    Regards, Ronnie
    in
  • Ronnie Marden Jul 01, 2007
    Hello Rotu and Noggin...
    Problem solved...
    Removed the panel in the freezer section and there was an ice block(age) in the drain on the bottom section....used hot water and a hair dryer to heat things up a bit and in less than twenty minutes the problem was solved..
    Many thanks for your help.
    Ronnie
  • 175 Answers
If you are getting water leakage from the freezer at the approx same time everyday, it would make sense that you have a clogged or frozen drain tube in the back of the freezer. Most fridges defrost themselves every 12 or 24 hours, depending on the model timer or controller in it. If you empty the freezer, take out the shelves, and pull the rear wall out (usually 4 or six screws that are in 2 rows down each side) and look in the very bottom under the coils. There should be a hole there going to the drain tray. if that hole is frozen over, or there is food stuck in it then pour warm water over and into it untill it flows through and that should cure your problem. Good luck!
Posted on Jun 30, 2007
  • 944 Answers
Got a couple of questions before we can really say much Does the refrigerator/freezer appear to be running as normal? is it perhaps always running at the time the water leaks for longer or more noisily than normal. Is the temperature of the freezer as normal? is there a particularly cold patch in the refrigerator , probably at the back or on the freezer side near the bottom? Where exactly is the water leaking from? and is there water collecting inside? Does the door seal properly at the base where the water seems to be coming from? Is there another major appliance with a heavy current draw that always goes on at the same sort of time? I'm thinking a water boiler, or aircon/heater, or the oven etc. Please post back, and we can start running through possible solutions :)
Posted on Jun 28, 2007
  • 1 more comment
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 28, 2007
    also have you fully defrosted it recently?
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 29, 2007
    Any info?
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 30, 2007
    Rotu has it right - only thing to add is that if you have somewhere you can stick all your food for half a day or so, then unplug it and do a full defrost - hopefully cures the problem without undoing anything.
    if you have no other place to put all your frozen stuff, then see if you can run the fridge/freezer down to empty first - it doesn't sound like anything in the workings of the fridge will suffer from a week or two before fixing it.
    Hope this sorts it :)
Where's is the defrost drain for Jcd2389gt
Click Here=> Maytag JCD2389GTW Freezer Compartment is where you see the drain begin inside freezer and behind panel labeled location 20. The other end of defrost dran comes out below refrigerator and near condenser fan motor. How to clean a defrost drain Click HERE=> How to Fix Fridge Water Leak, Thanks Sea Breeze
Much more on this page=> Leaking Refrigerators!
May 05, 2012 | Jenn-Air JCD2389G Side by Side...
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Problem
Make sure coils on back of unit are clean and not touching wall. Are doors closing and sealing with magnetic strip fully? Has some one changed settings without you knowing?
Dec 04, 2011 | Jenn-Air Refrigerators
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water leaking from bottom of freezer side
heatman101
Aug 28, 2010 | Jenn-Air JCB2280HES Side by Side...
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Leaking water
Mine just starting leaking also. Water gathers in bottom, then freezessolid. then additional water leaks out. I've check ice maker and door water line. confirmed by turning off water supply. Water continues to build in bottom. I think it might be the defroster. somehow the defrosting water is not draining? Check your out and let me know what you find.
Oct 28, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
209 people viewed this question
Top Jenn-Air Refrigerators Experts
Jose Pino
john h
Carmen Mikulic
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
