Question about Hitachi CinemaStar 7K160 HCS721616PLAT80 - 0A33482 160 GB Hard Drive
SLAVE DRIVE SETTING HITACHI MODEL
NEED SLAVE DRIVE SETTING
3 Suggested Answers
  • 3278 Answers
SOURCE: Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Hello.
For most IDE drives, if you REMOVE the jumper, the drive becomes a slave. But, you'll also need to change "drive 1" in your BIOS to recognize the second drive.
If you look on the drive, there should be a scheme as to the mode (Master, Slave,etc.).
Hope this helps.
Posted on Nov 07, 2009
  • 10406 Answers
SOURCE: installing Hitachi Deskstar 40 GB
Look at the "connectors" end of the disk-drive.
There will be a set of thin pins for the "data" cable,
and thicker pins for the "power" connector,
and a smaller grid of small pins.
It's these pins that will be labelled/engraved on the casing:
MA(ster), SL(ave), C(able)S(elect).
Move the jumper to the "slave" setting.
Connect to the power connector.
Connect to a "data" cable.
When you add power to your computer, it should recognize the drive.
Posted on Dec 26, 2010
How to set jumpers on a hitachi hard drive
Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
Aug 18, 2011 | Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Installing Hitachi Deskstar 40 GB drive as slave. Where do the connectors go. It says model IC35L060AVV207-0. Installing drive in Dell 4600
Dec 26, 2010 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
Setting for slave or master settings how to set
look at your hard drive itself, u should get all the info u need.
May 12, 2010 | Hitachi Deskstar 2 TB SATA Hard Drive
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
What is the jumper setting to make this a slave
If it's USB you shouldn't have to mess with the jumper settings but here is a site that appears to have them for TravelStar: http://www.ontrack.com/jumperviewer/ If the drive is not showing up in My Computer make sure there is a drive letter available for it to use. You can right click on the My Computer icon, select Manage and then go to Disk Management and see if the drive shows up there and then assign it to a different letter.
Mar 30, 2007 | Hitachi Travelstar 80GN 60 GB Hard Drive
Hitachi CinemaStar 7K160 HCS721616PLAT80 - 0A33482 160 GB Hard Drive Logo
47 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
