Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5920 alt f10 to use my recovery dsk mismatch d2d32
Either my new usb 8gb flash drive fooled the comp into thinking it was a driver or something or when I tried to turn on computer from sleep I hit the arcade deluxe and something downloaded and then the computer hybernated and now it won't boot up. I went through all the system recovery options. I don't have any drivers to install or media to install a drivr but when I push ok it goes to system 32 and wants me to open a file? It has file type as Setup Information. This is the block below File Name: which I don't know what to put here. I did the Alt F-10 on start up and was able to get to restore screen for my CD I made when I first got the comp, but it states D2D32 mismatch error. So I tried recover from factory setting and it gives the same error. I had gone to command prompt and it shows X:\windows\system32> I don't know if I should try anything here either. rstui.exe didn't help here either. I pushed the F2 setup and I could enable F12 but that didn't help me either...Any suggestions would help.
  • 5 more comments
  • lscott89 Feb 08, 2009
    acer 5920 alt f10, system recovery and disk recovery both have mismatch d2d32, what do i do?
  • Peachuz Feb 19, 2009
    If anyone has an answer to this, please let me in on it. I also was trying to do the eRecovery and reinstall to factory specs. I got the same message and it stuck on this and won't complete the reinstall of Windows Vista. Message D2D32 type mismatch. What's up with this?
  • Anonymous Feb 21, 2009
    same problem
  • westfieldnur Mar 10, 2009
    Hi All thanks for the answers. I ended up buying the recovery
    CD's from acer for the laptop as my DVD I tried to make when I first
    got it was blank (oops guess I didn't do that right). Anyway in
    about 8-10 days the disks arrived $30.00 for them it had 2 disks and 1
    other and it reinstalled fine. No further problems just sad I
    lost some disney pictures with my family. Hope that helps.
    I ordered the disks from acerpanam out of Texas.
  • Anonymous Mar 30, 2009
    yes, same problem
  • DEKR
    DEKR May 11, 2010
    can you get into safemode
  • DEKR
    DEKR May 11, 2010
    are you trying to boot from wincd or recovery
    Problem Solver:
  • 5 Answers
This a very common error. I too have suffered from this but after about 15 hours of fighting with it.. I fix it. I could not use the ALT + F10 keys as I would get the D2D32 Type Mismatch Error. So lucky me when I got my laptop from acer I made the recovery DVD's just in case. But to my suprise Booting from the DVD disk also would fail with the D2D32 Type Mismatch error. I even try maken new recovery disk with some luck. the new disk worked one time. But I started to run the recovery on disk one and when it asked for disk 2 I hit the power button thinking it would still boot, as I didnt want to wait for the recovery process to complete. So I ended up with a acer laptop with no o/s installed and was not able to use the Alt + F10 as explaned above or Boot using the recovery DVD's... so how did I fix this little set back... simple
I broke out the windows xp install Boot cd and Booted my system with that. let it run all the way to the partation/Format section on windows xp setup. I left the partation as it was and formatted it with the quick option. BE VERY CAREFUL AT THIS STEP... MAKE SURE YOU DONT FORMAT THE WRONG PARTATION THE 9 GIG OR 10 GIG IS WRONG. IT WAS DRIVE LETTER F: ON MY SYSTEM. JUST MAKE SURE IT IS DRIVE LETTER C: THAT YOU FORMAT...After it was done with the format I powerd down the system and tried to Boot from the Recovery DVD and it worked. No D2D32 Type Mismatch error. "{ But I let it finish this time around"} So to keep it simple. all you need to do is keep the partation the same, just format it and it your recovery will work. both ALT + F10 and /or the DVD"S Boot. it the ALT+F10 by chance dont work... theres a quick fix also. you need to files called MBRwrWin.exe and RTMBR2.bin and they have to be on the root of drive c:...{Root - just copy them to C: } and then from a command prompt with Adminastration {right click cmd } and type MBRwrWin install Rtmbr2.bin <Enter> ALT + F10 is now ready and fixed...
if you need help let me know or just to give some feed back
email me at cyberburn666@yahoo.com
Good luck it works. I just went from on os installed to vista... with factory recovery working like the day I got it....
Posted on Mar 10, 2009
I had same problem now fixed
Posted on May 07, 2014
  • Jon Mac
    Jon Mac May 07, 2014
    i have acer aspire 5920 wouldnt boot up,tried to restore to factory settings wouldnt work kept coming up d2d type mismatch tried lots of other ways to restore for weeks i dont have restore disc frying my brain i gave it one last go before i took hammer to it,after se
  • Jon Mac
    cont, i went into command prompt comes up. X:/windows/system32/ i put chkdsc C :/r it then ran program for over a hour until 100% complete i then restarted computer went into factory restore and restored no problems laptop now working fine ... hope it works for you.
I did a windows update and now my aspire 5920 wont start. have tried in safe mode with and without internet but still nothing happens. i don't have a recovery disc can anybody help?
Turn on your laptop n try pressing Alt-F10....n try restart it....generally acer laptops work properly after pressing Alt F10.....
Also if u r able to turn on ur laptopn in safe mode then try deactivate windows update...and restart ur laptop in normal mode.....
Mar 13, 2010 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won't do a recovery
BSOD is caused by hardware error or driver error. Disconnect all hardware except the basic. Motherboard, monitor, memory, hard drive. Unplug the wireless, cd/dvd drive.
Start the computer and see if the the BSOD returns. If not, one by one add components until you see the BSOD.
If you continue to see this screen without any hardware attached, then you most likely have an onboard component failing. (audio/video/memory failure)
Download and run the MS DART cd and check hardware starting with memory then hard drive.
http://www.microsoft.com/windows/enterprise/products/mdop/dart.aspx
This should determine what device is failing, except video or audio.
Jan 24, 2010 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won't fully recover
is hardware problem send to repair or a new one
Dec 29, 2009 | Acer Aspire 5920-6335 Laptop
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire 5920 problem
Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
WARNING:
This will erase everything you had stored on the machine!! ie data files, pictures etc...
Apr 12, 2009 | Computers & Internet
The system cannot find the specified file
It seems as though your windows is corrupted. To solve this I would recommend a recovery back to factory settings but this will delete all the data of the computer.
You can save your data by
using an IDE/ATA to USB adapter on another computer or take it to computer store.
To begin the recovery
Remove all external devices like printers, mp3 players etc
Ensure the laptop is running on ac power
You can start the Recovery from outside Windows by holding down ALT and F10 on the Acer BIOS splashscreen on power up.
Jan 19, 2009 | Acer Aspire 5920-6727 Notebook
Hi I have an Acer 5920, And im wondering how i can reboot it to it's factory settings. When i try ALT F10 It comes up and i do non-disk (partian drive) but when it processes it it comes up with an erre...
Ok, the computer, when purchased should have come with a Facotry Restore CD. If it did not, then the next step would be format and reinstall the operating system. Otherwise, Once a system has been used for some time, there are so many updates that the computer has automatically downloaded that there is no way to really work around them trying to restore the system to its factory settings.
One of the other reasons why your hard drive is coming back with an error on the partion is that if the hard drive hasnt been wiped properly recently, then when it goes to seperate the drive into multiple instances (i.e different parts to the same main equipment) the computer cannot proceed because it will find little files that are stored away in those Sectors. Like DLL files that were there from previous programs. or in some cases Randomly scattered registry files.
Oct 26, 2008 | Acer Computers & Internet
Restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
Sep 27, 2008 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
8,067 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
