Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
Pc setting for sony bravia
I am trying to connect a 32" sony bravia with a laptop via VGA male-to-male cable.
I am getting"unsupported signal",besides laptop refresh rate is 60 Hz and have tried all possible laptop resolutions.
Now the only solution remains changing Sony resolution,or pc setting of Sony.
Neither is possible.
Pc setting are not highlighted(perhaps not when connection is not established)and I am unable to make changes.
I cant either change Sony resolution from full to normal.
Someone that has identified this problem,or has got any knowledges may help please?
Also,a solution will help other readers who are experiencing the same problem.
Thanks in advance for your time!
Cheers,Tony
  • tony09 Mar 16, 2009
    Thank you.It seems quite a good option.I will try this solution as soon as I am able.
    Cheers
    Problem Solver:
  • 10 Answers
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Posted on Mar 16, 2009
MY PC IS CONNECTED TO SONY BRAVIA KDL 32S5500 VIA 9 PIN VGA CABLE BOTH SIDES AND THE SCREEN STOP WITH INDICATION NO SYNC AND RESTORES AUTOMATICALLY. CAN SOMEONE HELP.KIND REGARDS
Change the cable with an other one and check. If any among the sync carrying wire inside the cable has a break, this kind of display can be.
Jul 01, 2013 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Does the Sony VGN SF790 support hdmi cables? I would like to connect to my Sony Bravia TV
Hi.
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
Regards.
Aug 13, 2011 | Sony VAIO VGN-FS790 Notebook
Conecting my laptop to my tv via a vga cable coming up unsupported signal what do i do please help thank you
Reduce Display Resolution of laptop external monitor output, go to my computer > control panel > Display > Settings > Screen Resolution.
Thanks.
May 14, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
I just purchased a vga cable with two male ends, to connect my dell pc to my sony bravia flatscreen tv. i connected both ends between pc and tv as well as audio from tv into headphone output on...
You have to set the computer to emit the correct resolution for the monitor.
Try setting to 1020 x 768 and see if that works.
Do this in the "display" settings in the control panel of your computer. Also make sure the Sony is set to receive on the VGA port.
May 02, 2010 | Computers & Internet
Bravia 32'' hdtv says ''no signal'' when I connect my Sony vgn FW27OJ with 15 pin wire.
Connect the VGA cable to the external video port on the laptop, power up the Bravia first, switch the Bravia input to PC and then boot up the laptop. The Windows image etc will be automatically diverted to the Bravia.
Jul 05, 2009 | Sony BRAVIA Televison & Video
How to watch laptop in my Sony Bravia?
you need to clone the acer screen using ati utility
Jan 26, 2009 | Televison & Video
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
1,065 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
