Question about Motorola Mobility MA580 (612572111116) Cordless Phone
My Motorola MA580 sometimes work and others don´t
Hi to all. i just have a little question sometimes when i take the movil (handset) telephone from the base it don´t works like if there where no base and the Loudspeaker have too much sound ... almost like a BZZZZ. What can i do?????
  • Anonymous Nov 01, 2007
    Same issue. Cant get the handset and base to communicate
    S
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Posted on Mar 01, 2008
  • 31 Answers
It sounds as if the channel that the phone and base has selected during that session is bad, or being used by another system in the area. When that happens, try selecting another channel. You should be able to do this by depressing a button on the handset. Normally labeled "Channel". Please post further questions or comments. Please rate this solution through fix-it. Thank you
Posted on Jul 08, 2007
Clarity phone xlc 3.5 has static on it
Rather an unfortunate choice of brand name then :>) Take a look at the tips here
How to Remove Static Noise From a Cordless Phone ' It Still Works ...
https://itstillworks.com/12419015/how-to-remove-static-noise-from-a-cordless-phone
Sep 28, 2017 - Cordless phones transmit and receive radio signals to and from a base unit via antennae. They are convenient and can give you more freedom of movement when calling, but they are sometimes plagued by static noise problems. Find the small gray plastic box called the network interface device (NID) ... Missing: xlc ‎3.5
[PDF]3.5HS XLC3.5HSB - Clarity Products
shop.clarityproducts.com/media/.../XLC35HS_UserGuide_RevA.pd... Translate this page
F. R. A. N. ?. A. I. S. E. N. G. L. I. S. H. XLC. User Guide. 3.5HS. Additional Handset for select. Clarity products with ClarityLogic. XLC3.5HSB. XLC3.5HSB. XLC3.5HS .... telephone has been exposed to rain or water; if the telephone has .... Noise, interference or other calls heard while using the handset: • Make sure you are ...
Clarity Products - XLC3.6+HS
shop.clarityproducts.com > ... > By Product > Amplified Cordless Phones > XLC3.6+HS Illuminated talking dial pad with large buttons that speak the number that is pushed • Extra loud, flashing ringer with adjustable tones and voicemail indicator • Hearing aid compatible and TIA-1083 compliant • Direct connection to assistive listening devices or headset (2.5mm or 3.5mm) • Works only with XLC3.4+ or C4220+ ... Missing: static
Handset Registration; Troubleshooting - Clarity XLC 3.4 User Manual ...
https://www.manualslib.com > ... > Telephone > XLC 3.4 > User manual Clarity XLC 3.4 Manual Online: Handset Registration, Troubleshooting. XLC3.4 ... and the telephone. •. Make sure the handset battery is fully charged. •. Make sure the battery has been placed in the battery compartment. correctly. (The circular metal ... Noise, interference or other calls heard while using the. handset:.
Handset Registration; Troubleshooting - Clarity XLC3.4 User Manual ...
https://www.manualslib.com > ... > Telephone > XLC 3.4 > User manual Clarity XLC3.4 Manual Online: Handset Registration, Troubleshooting. XLC3.4 REGISTERING THE XLC3.4 Handset In Order To Use The XLC3.4 (or XLC3.1) Handset, You...
Clarity phone xlc 3 5 has static on it Google Search
Mar 07, 2018 | Clarity Lands Phones
How do I retreive messages from my motorola dect 6.0
Hi, with handset in idle mode, press MUTE (cassette icon), new messages will be played followed by any older messages, press MUTE to delete the current message.
May 03, 2014 | Motorola Mobility L702C DECT 6.0 Telephone
NO DISPLAY AND CANNOT MAKE A CALL
Hi, if you put it on the base and after one or two hours there's no charging indication on screen, maybe the battery is faulty or in the worst of cases the handset or base are faulty (electrical power blowout, lighting, etc.).
Oct 03, 2013 | Motorola Mobility L702C DECT 6.0 Telephone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I have (3) Uniden telephones in the house. We went on holidays for (2) weeks and switched off (2) of them. We switched them all on when we returned but now only one unit fully functions. The other two will...
Sounds like you need to re-register the 2 handsets that are not working properly. Sometimes the handsets must first be de-registered then re-registered to the base unit. Send a comment with the model number of the base unit and handsets if they are not original handsets and I will give specific information for your phone. I have included a link where you can download the manual for your Uniden cordless phone by model number.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 28, 2011 | Uniden Lands Phones
Can't register Motorola handset.
There is a very little that we can proceed to here, as these phones are known for the problem that you are facing & most of the customers that I have myself seen ... finally get rid of them buying new ones,
Let’s try resolving it though;
1.) Open battery compartment, remove battery. Also remove belt clip on back of phone. You might have to pry it a little.
2.) Pop off the access panel on upper back of phone. This panel merely hides two screws.
3.) Unscrew all visible screws, Separate front and back of phone. You might have to wiggle the pieces relative to each other. The rubber strips on the sides are held in place with dovetail grooves.
4.) The phone should come apart in three sections.
5.) At this point, get some cotton swabs and alcohol. Dip a swab in the alcohol and rub down the contacts on the keypad and little black pads underneath each button on the rubber membrane.
6.) Let it dry and re-assemble. Your phone should now work properly.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 21, 2009 | Motorola Mobility MD41 Expandable Handset...
One one ring tone with incoming call..........
Make sure the ringer is on .
• Make sure the telephone line cord and power adapter are plugged in properly .
• The cordless handset may be too far from the telephone base. Move it closer to the telephone
base.
• There may be too many extension telephones on the telephone line to allow all of them to ring
• If the other telephones in your home are having the same problem, the problem is in the wiring
• Other electronic products can cause interference to your cordless telephone. Try installing your
• Test a working telephone at the telephone jack. If another telephone has the same problem, the
problem is in the telephone jack. Contact your local telephone company (charges may apply).
• The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
• Remove and re-insert the battery and place the cordless handset in the telephone base.
• Wait for the cordless handset to synchronize with the telephone base. Allow up to one minute
for more info download this http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i3.pdf
Apr 01, 2008 | Vtech Cordless 6041 Phone
Motorola 580 handset not working
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Lots of static heard during use of this phone.
Time for a new phone. Most likely there are some bad solder connections and they could be anywhere. A 2 year old battery should not cause such severe problems so I'd spend the money on a new phone before a new battery.
Jun 27, 2007 | Motorola Mobility MA580 5.8GHz Digital...
Motorola Mobility MA580 (612572111116) Cordless Phone Logo
144 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
