Question about Husqvarna Garden
Tank vent on husqvarna 345 plugged
Tank vent will not vent
  • 16 Answers
SOURCE: husqvarna 345
I think they have a allen screw through hole in av spring
Posted on Nov 11, 2008
SOURCE: Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: is there a hose that attaches to gas tank vent on
You can find an answer to your question here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Uncheck "Manuals" check "Illustrated parts lists"
I think your answer is on detail "J"
pns 503 60 04-01 and 501 62 98-01.
All fuel system components can be found on these illustrations. I wish Husqvarna included nomenclatures but they don't. Your local Husky may be able to verify by telephone these are indeed your fuel vent.
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
It might be a good idea to save a copy of both your Manual and the IPL to your computer. HTH
Lou
Posted on Nov 08, 2009
dontbother10
  • 2220 Answers
SOURCE: my Chainsaw Husqvarna 345, won't start. With
I hope 2 different problems Marvin. I think the starter is most important, after you reply with findings we will take on the likely fuel delivery problem. Please do this and post back (below) with what you find.
Starter Handle difficult to pull:
1. Remove the starter cover. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots aligned and the key intact? Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Starter fluid removes what little lubrication is provided by the fuel mix. I suggest a teaspoon of mix into open carburetor throat or the plug hole. Do not go to speed with the air filter removed.
Posted on Mar 29, 2010
Testimonial: "I think this is excellent advice. Thankyou very much"
  • 4088 Answers
SOURCE: husqvarna 345 bar oiler
Remove the bar and chain. Start the engine and observe the oil delivery port in the side of the engine case. At a fairly fast speed, the oil should ooze out of the port. If little or nothing, check the pump, lines, and in-tank filter. If ok, clean the bar drive-end holes of sawdust and dirt, especially the small passages that go from the large holes out to the chain groove. Clean the entire groove and the outer end sprocket. Reassemble and test the oiling by running the bar tip at speed in front of a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Posted on Apr 09, 2010
Husqvarna 345 chainsaw cuts off when hot
It sounds like it may be getting lean at that point, and it could be something like a tank vent. When this happens, open the filler cap, close it, and see if the saw will start.
Another easy test is to fill the tank completely in the event that a small hole has formed in the fuel line inside the tank. I doubt that is the problem, but worth the time to check before moving on to other tests.
If that doesn't work, disassemble the carburetor and clean all passages with non flammable brake cleaner (carburetor cleaner can damage check valves and soft small engine components). Sometimes dirt can accumulate in places that affect how the diaphragm moves.
If none of this works, have a service shop evaluate the unit. Pressure and vacuum tests will reveal the culprit(s) and determine if the saw qualifies for service.
Mar 22, 2014 | Husqvarna Garden
I have a Husqvarna 435.Hard to start.When it runs, it has no power.It does the same as if it runs out of gas.I loosen the gas tank plug, then it starts and I'm good for 10 minutes.I also have a Husqvarna...
Sounds like the fuel cap on the 435 is not venting properly. Change the fuel cap and do not overtighten. Should correct your issue. The 435 is a nice light weight unit.
Feb 14, 2014 | Husqvarna Garden
What holds the tank vent in a on a 345 Husqvarna?
The early machine had two white pellets pressed into the side of the tank, the later machine has a white breather assembly which simply pushes into the tank, it is just a tight fit in the tank there is nothing else to hold it in.
Jan 25, 2013 | Husqvarna Garden
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
Unable to locate adjustment control for chain oiler model 345 husqvarna chainsaw
Not all 345 machines had an adjustable oiler, it is retro fittable if it does not, however if it hs an adjuster, the screw is located on the bottom of the saw between the cranckcase and the fuel tank, just below the sprocket, there will be an oil symbol and a - and + sign there, the pump is three position, for 13/15/18" bars.
Oct 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Fuel leaking at the fuel filter attached to fuel line outside of fuel tank . The little niple that the fuel line connects to, that has a filter at the end. This is on my model 345 HUSQVARNA chain saw....
The fuel tank vent is whats leaking.Some saws that have primer bulb set up were sent from factory with the primer return hose not being long enough so it will either come off or break at the tank vent/filter.I have seen some saws leak around the tank vent when temps are below 10 degrees F due to tank plastic distorting from the cold weather.
Feb 22, 2010 | Garden
Is there a hose that attaches to gas tank vent on husqvarna 345 e chainsaw
HusqvarnaUSA.com
06 1500198
Lou
Nov 08, 2009 | Husqvarna Forest & Garden No.967012396 345...
I cant get oil to the chain on my husqvarna 345.
You may have a problem with blockage in the oiler system somewhere. Try emptying out all of the bar oil and swishing some gas around in the bar oil tank to clean it out. This will work some of the time. Sometimes you have to take the oiler off and blow thru the lines into the tank,( make sure the oil fill cap is off) and blow into the oil tank out thru the line to clear out any debris . The adjustment for the oil pump should be on the bottom of the saw. Here is the manual with the procedure on page 32 of the manual. Hope that helps you.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140235-95.pdf
Jun 12, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
120 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
