Question about Kitchen Ranges
Bulb holder needs replacing
Can't find one anywhere....any suggestions for an alternative that will work?
  • 51 Answers
I have replaced them if they are the ceramic type with either a metal clip or the kind that hase one screw holding it in place with one from a cheap bathroom light fixture. take a look at some other fixtyres at home depot and see its the same as the one on your hood.
Posted on Jan 06, 2013
Left rear turn signal on dodge ram 1500 won't work. bulb replacement didn't help.
Just had a similar question last week, and the solution was a bad socket/bulb holder.
You might try and see if there is current in the brake light wire leading to the bulb holder.
I have used a jumper wire and a safety pin to test the wire behind the socket.
I pierced the plastic insulation of the brake light wire with the point of the safety pin, and either use a tester or even a good working bulb and a good ground wire.
Be blessed.
Jan 27, 2013 | 2006 Dodge Ram 1500
Need a replacement bulb for a Redline Nebo flashlight
Hi, replacement bulbs can be found at amazon, click here and take a look: Amazon com flashlight replacement bulb. Cheers
Nov 02, 2012 | Nebo Redline Tactical Flashlight Strobe...
What bulb do I need to get my headlight working
Hi there:
I suggest go to the Vauxhall website, sign up for "My Vauxhall" (it's free) and you can then download a manual in pdf format. The earliest manual for an Astra is 2002, but the headlight bulb changing instructions will be the same, and should be on pages 212 onward.
If its the dipped headlight bulb then the bulb itself (H7 fitment) sits inside a brown L shaped bulb holder that twist fits into the lens. Just twist it anti clockwise and remove - disconnect the multi-plug connector from the bottom of the brown bulb holder first tho.
If however its the main beam bulb (HB3 fitment) then the bulb holder is actually part of the bulb and comes as 1 complete unit.
I trust from your description that its the dipped bulb thats gone. Once its light, have a look and see what u think
It really is straight forward and you shouldnt have any issues. If you manage it - then note how the bulb fits into the bulb holder and fit the new bulb in its place - dont touch the glass though so use the base to push it into position... refit, twist into position making sure the 3 tabs around the edge of the bulb holder are correctly seated and fit the electrical connection in place.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Oct 30, 2012 | Vauxhall Astra Cars & Trucks
Need help
this is probably a defective bulb.for the price,replace the bulb making sure to check the contacts on the light bulb holder to make sure that it is free of corrosion.i would also suggest that you invest in some dielectric grease to insert on the metal contacts before reinserting its replacement.
Dec 19, 2011 | Cars & Trucks
Removing headlights BMW x1
Open your BMW's hood. Locate the black bulb cover for the bulb you need to replace. It is located behind the assembly in the engine compartment.3 Reach down into the compartment and turn the cover to the left to pull it off.4Turn the bulb holder left and pull it out of the assembly.5 Remove the old bulb from the holder. Pull it straight out.6 Insert the replacement bulb into the holder.7 Replace the bulb holder into the assembly and turn it to the right.8Replace the bulb cover and turn it to the right
  • Dec 03, 2011 | 2011 BMW X1
    How to replace headlight bulb in 1987 toyota camra
    For an 87 specifically, I don't know the answer, sorry. There were at least 3 designs used in the 93-94 models alone. If it is anything like them, you have to either
    - press in the plastic barb clip on the centre of the wiring connector at the back of the globe housing, and pull down on the wiring connector to disconnect it. Then rotate the globe holder anticlockwise and withdraw it. Don't touch the new globe glass with your fingers, or if you have, clean it well with metho. Then installation is in reverse. Or for a different design,
    - alternatively, unplug the electrical connector. Then turn the hard plastic cover, at the back of the headlight globe holder, anticlockwise and remove it. Then remove the rubber cover underneath. If you are replacing an outer bulb remove the bulb spring clip, first taking note of how it is fitted. On an inner globe there may be a covering socket over the globe itself. Remove that, and the spring clip underneath. Replace the globe. Installation is in reverse, making sure all bits are in position, and the 'lock' mark on the hard plastic cover is facing upwards.
    Nov 16, 2011 | Toyota Camry Cars & Trucks
    I have a used Beverage Air model # MT17-54. What size light bulb do I need, Lenght and wattage.
    I Have The MT15-54 Used The Same Very Hard To Locate Bulbs & $$.
    F28T8CW4 is a 28inch, Plus Ballast Replacement Cost(s).
    I Got Rid Of That Setup, Removed Both Ballast and Lamp Holders.
    Install Two 13W T2 Twister Fluorescent Energy Saving Screw In Bulbs,
    I Call Them The Pig-Tail Bulbs, Less Energy & Heat.
    Obtain a Dual Levington Incandescent Porclein Bulb Holder Assy, Part# 4005 and Mounted Inside Cooler/Front Side Only/Top Center
    Between Evap Coil/Fan Cover & Sliding Door's, Little Room, But
    Works Great w/Bulbs.
    Lights Entire Inside, Plus If You Like Color Bulbs, Add's a Cool Look
    At Night. Use Same Light Switch Installed From Bev-Air OEM.
    Jun 13, 2011 | Kitchen Ranges
    Audi A4 need to replace rear brake light on audi a4
    Inside the boot is a plastic cap embeded in the boot liner. Remove the cap to reveal a screw. Undo the screw and the whole rear light cluster will come away in a sideways and not rearward direction to reveal all of the bulbs. Hope this helps.
    Jun 04, 2009 | 2003 Audi A4 Cabriolet
    FM/AM GE Digital clock radio model#7-4966 display bulb burned out
    Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
    In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
    Dennis60
    Jan 27, 2009 | Audio Players & Recorders
    Kitchen Ranges Logo
    82 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
