Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
My TAWS800JQ1 washing machine drum seems like it has shifted and is off balance
The drum on the washer can be lifted and shifted in all angles inside the washer. Just purchased the washer used from a friend and was told it worked great, I used it and when it gets to the spin cycle is violently shakes and seems like it's going to vibrate all the way across the floor and makes LOUD banging noises.
    Sergeant:
  • 291 Answers
The bearings are likely shot. But it's possible the spanner nut that holds the basket in place is loose or damaged. Remove the agitator to check spanner nut. Changing bearings is a big job, but if you are handy with tools and good at keeping your cool you can do it yourself.
Posted on Jan 06, 2013
  • 641 Answers
SOURCE: drum off balance
Open washer's cover and look for a released or a malfunction shock absorber.
Posted on Aug 11, 2007
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
It's either a bad suspension spring or you have a crack in the tub support.
Posted on Jul 15, 2008
  • 92 Answers
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Posted on Feb 06, 2009
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
I am attempting to repair my uploader whirlpool washer, I have removed the drum, however I hear lot of water inside the drum still, what should I do? is it normal?
Yes that is normal. That is your balance ring. It's an ingenious device that acts as a counterweight to keep the tub balanced. All is good.
Jan 12, 2013 | Whirlpool Washing Machines
Washer shakes violently!
Do you not know that unbalanced dry clotrhes become super unbalanced wet clothes! If you put too little clothing in the front loader, the weight will be in one place on the high speed turning drum. If you put in too much, the load will shift to a few locations but still be out of balance. Rather than "dance" the Chubby Checker way with your machine, try stopping it when it does "the dance" and redistribute the clothing around the drum!
Dec 26, 2012 | Dryers
We have balanced our front loading washer 4 times and its still shakes uncontrollably once it starts spinning how do we fix this
It may be the bearings in the drum going bad or could be a missing piece of counter weight. Reach inside and lift up on the drum. If you can move it much or it bangs or pops when you lift up on it, the bearings are gone.
Let me know what you find.
Aug 08, 2010 | Frigidaire ATF6000ES Front Load Washer
When my washing machine is spinning it makes a terrible banging noise! and i cant get it to stop. also, the legs of the washer are stripped and i cant adjust them so one is higher than the other one
it sounds like the balance springs inside the washer have come off or broken if so when ever the washer spins it jumps about and the drum inside bangs around to check if the springs are broken open the washer door and try to lift the iner drum up if it lifts a lot the springs are off or broken to help get it level try packing out the leg with a small strip of wood (ei: a bit of ply wood) would do to stop the washer from tipping its that or if you can get the striped leg off put some steel washers over the threds to pack the leg up
Mar 20, 2010 | Washing Machines
Drum off balance
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Washing machine
WASHING MACHINES HAVE SPRINGS ON THE BOTTOM OF THE TUB THAT ARE MENT TO KEEP IT FROM SHAKING, LIFT THE LID BY INSERTING A SCREW DRIVER SIDE WAYS BETWEEN THE LID AND THE FRONT THEN TURN THE SCREW DRIVER, NEXT UNDO THE SCREWS ON THE RIGHT AND LEFT HOLDING THE FRONT ON TO THE MACHINE, NOW IT WILL SLIDE OFF AND YOU CAN SEE THE SPRINGS
Dec 18, 2007 | Estate TAWS800JQ Top Load Washer
ESTATE TAWS800JQ1 WILL NOT SPIN
both of your problems are the clutch assembly if you are handy you can do this repair
Dec 04, 2007 | Estate TAWS800JQ Top Load Washer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
