Question about Panasonic Matshita Computers & Internet
Matshita dvd-ram uj8c0 will not copy disc- why?
Matshita dvd-ram uj8c0 will not read a disc.
  • 198 Answers
SOURCE: Matshita DVD-RAM UJ-840S Problem
If you can remember a time when it worked, the simplest solution may be to use system restore to a time when you think everything worked. If that doesn't do it, go to Control Panel, open device manager, and and check for any yellow checks for your CD/DVD ROM drives, and your sound, video and game controllers. If there are none, your system is go. Also go to your audio manager on control panel, and set it up for whatever speaker configuration you have. But most likely, your CD/DVD burning program may be corrupted. Remarkably, the drives don't work unless you have a functioning non-microsoft CD/DVD burning program. They don't need drivers. Find out what program you have by downloading Belarc Advisor, a free program which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), and will also inform you if you are missing any needed Windows updates. Once you know what CD/DVD burning programs you have, go to Acer and download any updates (you can't go to the manufacturer of the program, because they make special editions for different computer manufactureres). If that doesn't fix the problem, you can find and reinstall your original program (you may have made copies of all your programs when you first bought your Acer). You can copy the original programs that came with the Acer using Acer eRecovery Management. (You can read about your Acer by clicking on "All Programs" and then on "AcerSystem", where you will find your manual, where you will find the following info: The eRecovery allows you to backup/restore the factory default image, and reinstall any applications and drivers. (In this instance you want to reinstall your CD-DVD burning programs). You just need to select the Burn Disc button, then select the application you want to burn to the disc--in this case, you CD-DVD buring program you identified with Belarc, burn it, then reinstall it. (You might want to burn all the applications the computer came with, just to have them for backup). That should get you going again. Let me know if you run into any problems.
Posted on Mar 24, 2008
  • 476 Answers
I beleive that you may need to reinstall the drive and update the drivers,
if youve got XP OS then you will need SP2 updates also.
Failing that a new drive is probably the only option.
If the 2.5 drive option is too expensive you could get an external device for this function or if you have a network
(more than one computer)you could share the device across the network from the other computers device tray.
Please rate me if this helps thanks
Posted on Jul 16, 2008
SOURCE: my problem with matshita dvd ram uj845s not working
Do you guys know how to fix the 850's one?
Posted on May 26, 2009
  • 608 Answers
SOURCE: Is the Matshita UJDA775 DVD/CDRW a DVD Writer ?
Download this little program DISCinfo 1.6.1. When you run it it will give you all the info you need about all your drives. It's good, I use it. Get if from here [http://discinfo.rpc1.org/#Download]
Posted on Mar 19, 2010
aferrell09
  • 105 Answers
SOURCE: Matshita UJ DVD-RAM 860s can't burn CDs or DVDs
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start
Start button, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
The system will automatically rebuild the registry records when you restart your computer. Hope this helps.
Posted on Mar 27, 2010
Why won't my MATSHITA DVD-RAM LF-D211A mount any blank discs on my desktop?
If you open up System Preferences and click on "CDs & DVDs" does it look like this?
.... Especially the top two items ....
Jul 20, 2014 | Apple Mac OS X 10.4 Tiger for Mac
Matshita Dvd-ram UJ-861H ATA Device Not Working
Use this link to find possible answers to your problem. It is in the Microsoft Community
HP Pavilion with Vista Matshita Dvd ram UJ 861H ATA Device is disabled...
Feb 20, 2014 | Computers & Internet
Matshita dvd ram uj8b1as
Hi, my lenovo G570 laptop has a Matshita DVDRAM UJ8B1AS drive, it wont read any disc that is inserted,it starts to spin but nothing else. It doesn't show in My Computer either. Do i need to re- install the driver, if so where do i get it from?
Apr 02, 2012 | Lenovo INC 43344QU G570 Ip Pdc20 156...
Busco matshita dvd-ram uj-840s driver para el windows xp. Alguien me puede ayudar? No lo encuentro en ninguna pagina. En la pagina oficial solamente existe para el windows 2000. Gracias.
Not sure of your question; I read only English.
There are many sources for the drivers for your DVD; many would liek you to downlaod and use their driver update programs. An advantage is if there is ever an additional update the program will let you know. Here are two examples that you might consider as sources for an updated driver:
http://driver-helper.org/matshita-drivers/matshita5/matshita-dvd-ram-uj-840s-ata-device-driver-download/
http://www.driverboost.com/lp/drivers/update/Matshita-System-Drivers.php
Dec 28, 2010 | HP Computers & Internet
Matshita DVD-RAM read DVD/CD but can not write.
Reformat computer to original setting. I've done this before and its working.
Nov 02, 2008 | Lenovo 3000 V100 Notebook
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
My matshita uj-860s disc drive has stopped working
In my case, MATSHITA DVD-RAM UJ-860S did not want to write CD-R,-RW Verbatim using software NERO 8, but is easy to write their own software windows XP.
in the Log file was as follows:
Could not perform start of Disc-at-once
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Power calibration error
whether
Invalid field in parameter
E: MATSHITA DVD-RAM UJ-860S
ACTION! :)
Change in method of recording NERO 8 Burning mode: DAO (Disc-at-once) at Burning mode: TAO (Track-At-Once) all have established!
Simply drive MATSHITA was UNSUPPORTED software producers to write disks.
Updating the software to burn CDs, as is windows XP supports the recording and includes drivers for the drive! :)
Apr 17, 2008 | Computers & Internet
MATSHITA DVD-RAM UJ 85JS problem
I have mashita DVD-ram UJ 850s in acer aspire 3100 that wont play vide while it only plays sound
Mar 05, 2008 | Toshiba Style Bay DVD-RAM Drive Kit...
Computers & Internet Logo
1,210 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
