Question about iLO V27DMBX Television
Dead LCD 1 mth out of the warranty and it died. When I plug it in, you can bearly hear a snap/crackle come from the speakers but thats all. No pic or sound. Has anyone experienced the same and what repair was required? If anyone has a service manual or a user manual in pdf format, can you send it to me? Thanks in advance
  • Edward Garcia Jun 28, 2007
    just like the pic, it's a iLO V27DMBX LCD TV
    just like the pic, it's a iLO V27DMBX LCD TV (not a plasma)
    Problem Solver:
  • 13 Answers
What kind of LCD are you talking about?
Posted on Jun 28, 2007
SOURCE:
Connection to other speakers on my Dolby digital speaker system. I only have one working.
Double check that you have the correct speaker wires in the correct terminals. If not sure a AA BATTERY tapped quickly across two wire leads and you will hear it crackle/snap. Very helpful when trying to identity speaker Chanels. If no sound. Check wires and speaker. Some speaker boxes will have: built in adjustable crossovers, inline fuses to protect speaker from blowout(also in some stereo units) and then could always double check fade and balance. # of channels playing, and a few other things as we go into the future
Jan 04, 2015 | Audio Players & Recorders
Cracking speakers when tv turns on
If other electronics are too close to a TV this is a common problem. Try moving the 2 items at least 2 foot away and see if that helps.
You may not want to leave them there, but at least you will know if that's the problem!
Mar 01, 2014 | Bose Cinemate Series II Speaker
Element elchs321----tv cuts off on its own. when tv is plugged up, the light at the bottom is red and you can hear a crackle, the light turns blue but no picture or sound. Help
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. That crackling sound is the capacitors burning out.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 15, 2010 | Element ELC-HS321 32 in. LCD TV
Sound crackle on warmup, now no sound at all
Turn your volume up slowly if you can hear audio. If no audio at all. Could be loose/cut wiring on the speakers.If both speakers are dead could be fault on amplifier side.
Apr 04, 2009 | Televison & Video
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Bose 901 Series IV BLOWN?
Yes, if you hear any sort of crackling sound, that means it has blown. Given the cost of these units, I would suggest repair. I would also suggest contacting Bose, as many of their products have a lifetime warranty, so you might be in luck. Although, blowing your speakers because you made your speakers go louder than they were supposed to, is no covered in the warranty.
You can approach the repair in 2 ways..
1) Send in to Bose for repair - suggested
2) Take it to a service center, and see if they will be able to recone the speakers or replace. Most service centers are familiar with the 901 series, so you should be ok. If they have no idea what your talking about, stay away.
But yes, they are worth fixing.
- OPTiC
DJ & Pro Audio Repair
Jan 17, 2009 | Bose 901 VI Main / Stereo Speaker
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
iLO V27DMBX Television Logo
66 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
