Question about Broan-NuTone Best By Broan BER02IS 48" Island Hood Central Housing w/ Internal Blower, 500 CFM & Electronic Contr...
I have a Broan LR31619 range hood and I need to replace the bulb holder....can't find one anywhere...any suggestion? I am ion Canada
SOURCE: Broan Allure II
my range hood lights would only work on highest setting. nothing on low or medium setting. fan working fine. I tripped the breaker off then on again at the electrical panel and behold, everything works perfectly fine now. don't know why it worked but it did!
Posted on Dec 02, 2007
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: 42" Allure II Broan Range Hood I put a new bulb to replace
hey guys
These are halogen bulbs, so you must be very careful not to touch them with your bare hands. Use a paper towel, or even better latex gloves. The smallest bit of oil from your skin/ hands will cause the bulb to blow as soon as they get warm
Posted on Nov 25, 2009
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
http://cdn.appliancepartspros.com/images/product/cache/broan-light-fixture-assy-sv16569-ap5178165_01_l.jpg
Feb 16, 2015 | Cars & Trucks
Bulb holder needs replacing
I have replaced them if they are the ceramic type with either a metal clip or the kind that hase one screw holding it in place with one from a cheap bathroom light fixture. take a look at some other fixtyres at home depot and see its the same as the one on your hood.
Jan 06, 2013 | Kitchen Ranges
How do I unscrew bulbs to replace new ones??
I've not seen any range hood that used an unconventional socket so; counterclockwise.
Dec 18, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
Jan 27, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Lighs
Saint...first...have a look at the bulbs. Make sure the bulbs are 'really' good and that the sockets are clean inside and undamaged. Second, the switch might be bad.
Nov 15, 2007 | Broan-NuTone Broan Range Hoods Deluxe...
Kitchen Ranges Logo
232 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
