Question about Marantz SR 5005 AV receiver - Black
Marantz 5005 remote not working
Remot worked fine yesterday. Today would not work.. Battery terminals had some corrosion. Cleaned them the replaced with new batteries.. Now on off and volume down works but nothing else.. Red light does not come on when pushing buttons
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Posted on Jun 13, 2011
kerguney
  • 577 Answers
SOURCE: I have a Marantz SR
You have a nice piece of Stereo...I believe you have mistakenly selected the" display mode OFF" function..,Here is the info that you can reactivate it..
If you need a soft User Manual here is the link for it too..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)...please insert some words in "
My Testimonials "
Hope this helps!
" display mode OFF"
You can select the display mode for the front display
of the SR7001.To select this mode, press the DISPLAY on the remote control or the front panel.When this button is pressed, the display mode is switched in the following sequence.Input Mode ? Surround Mode ? Auto display OFF ? Display OFF ? Normal Mode ? Input Mode Normal Mode: Displays the selected input function. If the function has been renamed using the Function Rename feature (see page 26), the renamed name appears on the display. Input Mode: Displays the input mode set via the Function Input Setup feature (see page 25). Surround Mode: Displays the status of the selected surround mode. Auto Display Off mode: The display is off. But, if you make a change to the unit such as the input or surround mode, the display will show that change, then go back to off after about 3 seconds. When changing the volume, it is not displayed. Display Off mode: The display is off completely. Note: • Only the DISP indicator will be illuminated on thefront display in display off condition
http://www.scribd.com/doc/53431794/Marantz-SR-8001-Owners-Manual
Posted on Jun 23, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Marantz SR5000
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Posted on Aug 22, 2011
Why doesn't it turn over or start?
Take the car, or the battery, to a car parts store and have it tested. Usually the problem is a bad battery, unless it is a problem of corrosion on the terminals.
Understand that corrosion can not only prevent starting, it can prevent the battery from taking a charge to recharge it from the starting draw.
The terminals must be not only clean, but "metal-shiny-bright :" on the posts and the terminals themselves.
God bless your efforts.
Mar 04, 2016 | 2003 Honda Odyssey
I need to know if the remote is defective or if it is the TV.
early remotes work by infra red light ( small bulb or opening at the front of the remote )
turn on the camera of your cell phone -ipad and aim the remote at the camera lens
if you see a white spot on the screen when you press the remote button , it is working
Nov 28, 2015 | Televison & Video
Mazda 323 wont start
Use voltmeter to check the battery connections and grounds. Corrosion problems at the battery terminals will contribute to this problem. You can still have lights, but not enough amperage to start the car. Bad battery can also do this. Have the battery load tested before doing anything else.
Aug 21, 2013 | Cars & Trucks
99 isuzu rodeo remote wont work
Flip the battery over and see if the remote will operate with that orientation. You could check the battery to make sure it works.
Also check the contacts. Can be cleaned with Q-tip lightly moistened with rubbing alcohol. (Don't overdo the alcohol, you don't want to wet anything except the contacts.) If there is corrosion, can be cleaned carefully with a pencil eraser or with fine sandpaper. Shake or blow out any debris.
Hope these thoughts help. Good luck
Nov 22, 2012 | 2004 Isuzu Rodeo
Nannieandnoodie@rca remote usually works my sharp tv but quit yesterday
try to replaced your battery then if still doesn't work just cleaned all the contact at the PCB. try to checked also possible loose contact at the battery terminal and infrared sensor.
Apr 10, 2011 | Televison & Video
[09-29-10 at: 11:08p.m. I own a 1992 Acura Integra, hatchback 1.8L engine. Ran great, ALWAYS STARTED IMMEDIATELY, until today, when AFTER, I cleaned the corrosion off the POSITIVE battery terminal...
There is always the chance that when removing your leads that one or both of them is no longer fitting tightly on the cable.
On the other hand, since your battery is old enough to have had corrosion needing attention with a wire brush then perhaps it is TOO old and needs to be replaced.
Sep 30, 2010 | 1992 Acura Integra Hatchback
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
Need reprogramming instructions for gmc yukon
Hi
dose the other remote work?
check to make sure the battery clip is not broken in the remote
you shouldn't have to reprogram unless you have replaaced the remote
Jun 02, 2009 | 2003 GMC Yukon
Cyberhome dvr1600 remot
try replacing the decoder.. i have same problem but i solved it by replacing the decoder... the new one..
Mar 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Marantz SR 5005 AV receiver - Black Logo
19 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
