Question about RCA RCR311B Remote Control
Set keyless remote for Nissan xterra
I am trying to set my remote for keyless entry into my Nissan xterra
Key Fob Programming instructions...
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Posted on May 13, 2009
I AM TRYING TO PROGRAM MY RCR311B TO OPERATE MY TOSHIBA TV CAN YOU SEND ME INSTRUCTIONS
Posted on Jan 24, 2009
  • JOE DAVIS Jan 24, 2009
    i did this once before but forget how
2005 Nissan Sentra, the keyless entry locks the doors but does not unlock them.
does your unlock button work in car? If it does, do you have another keyless entry key fob? If so does it work? If you just replaced the battery you can try removing battery and cleaning contacts within remote. I know some of the nissan altimas had the same issue and the only solution was a new key fob. Good Luck
Jan 04, 2013 | 2005 Nissan Sentra 1.8
Where is the keyless entry module on a 2002 xterra
If you mean the 'Smart Entrance Control Unit,' it is located at the parking brake release lever on the driver's side according to autozone.com.
Look at the bottom center box and it has a diagram of it.
FIG : Power door lock components and harness connector locations with keyless entry-2001-2004 CLOSE X printdiagram_txt.gif print_icon.gif
Dec 19, 2010 | 2002 Nissan Xterra
I have a 2003 nissan xterra...can't get the idiot lights for the airbag and check engine soon to go off...and the keyless entry will not work, battery in the keyless has been changed and the vehicle has...
Take it to a different shop. Something is wrong with it. However, when the airbag light is on, that means the airbag will not deploy in an accident. You should have that fixed first. The dealership is the best option for making the keyless entry work. If this was at all helpful, please rate. Thanks for asking.
Jun 29, 2010 | 2003 Nissan Xterra
Door locks while no one is around on my 2002 xterra
realx my dear frd...its bcoz of loose connection between the wires...u better leave u r car in a very good service station so that they will take care of all the prbs in the car....this even happens if rain water enters inside the car while drivin..rain water enters through the window gaps...so tel u r service provider make up all the windows properly...and it often happens bcoz of wiring so dont worry boss!!!!
Jul 24, 2009 | 2001 Nissan Xterra
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
HORN WILL NOT SOUND BUT DOORS WILL LOCK WHEN I USE MY KEYLESS ENT
The title of you problem mentions the horn but the actual problem mentions the flashers? Which is it? You can turn the 'horn beep' feature on and off by simultaneously holding the lock and unlock buttons down on the remote for about 3 seconds or more. When the horn feature is turned on you will hear the horn, and when it turns off you will only see the lights flash.
Nov 12, 2008 | 2005 Nissan Xterra
Door lock
Make sure the battery on your Keyless Entry remote is a working battery.
If thats not it, it could very well be the actual button on your Keyless Entry remote being faulty. But it could also be a relay in the car aswell. Depending on the cost of a Relay versus the cost of a Keyless Entry remote, I would try to replace either/or and try again, whichever is cheaper. The Relay may be cheaper, but your Key-FOB sounds like it could be the cause.
May 16, 2008 | 1994 Nissan Maxima
RCA RCR311B Remote Control Logo
569 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
