Question about Nintendo Wii Fit - Balance Board + Game Console
Wii Fit board is not measuring my weight correctly
I haven't used my board for some time and finally tried WiiFit today. There is a 20 lb difference in the weight that it registers. (It looks really good but it's not accurate). Any suggestions on how to fix this
JOHNNY2hotty
  • 41 Answers
SOURCE: wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
Posted on May 08, 2008
ctf1800
  • 4402 Answers
SOURCE: Wii Fit Hula Hoop Game
try standing as far back as u can, then jump and then do twenty jumping jacks.
Posted on Nov 25, 2008
SOURCE: wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Posted on Feb 09, 2009
  • 33 Answers
SOURCE: Wii frezees after inserting Wii Fit Disc!!
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Feb 26, 2009
  • 80 Answers
SOURCE: We are a college and have purchased a wii fit
No. I believe that the software can only handle up to 8 despite the number of Mii's that you have on a system. Unfortunately, I think the best solution is three Wii consoles. You don't need a new balance board and software (unless you plan on more than one using it at the same time), but you will need to have three separate Wii systems.
Sorry about that. Good news is that the Wii console is getting easier to find than the fit. ;)
Posted on Feb 27, 2009
Wii board does not show correct weight, sometimes im a stone heavier or half a stone lighter my actual weight
The Wii balance board isn't known for being hugely accurate, I wouldn't pay too much attention to what it says your weight is.
May 10, 2011 | Nintendo Wii Fit for Wii
When i click the button on the wiifit board to connect to the wii, it connects at a second. then loses connection and wii says it is lost. the button on the board just keeps flashing or goes off
If you haven't already tried to replace the batteries, do this (if you have, this is useful information to include in your problem description :D). If that hasn't worked, you may need to re-sync the board with your Wii.
1. Power on your Wii console (there is no need to power on your balance board at this time).
2. Open the SD card slot cover on the front face of your Wii to reveal the red Sync button on the Wii.
3. On the bottom of your balance board, remove the battery cover to reveal the red Sync button on the balance board.
4. Press the Sync button on the balance board (there is no need to keep it depressed; simply press and release). You will notice the power LED on the power button on the balance board blinking.
5. Now press (and release) the Sync button on the Wii console. After the LED stops blinking, the Sync is complete.
If this does not fix your balance board, it may need to be repaired or replaced. Contact Nintendo and provide warranty information if applicable.
May 04, 2011 | Video Game Consoles & Games
First time user of the WiiFit Plus Nintendo. Need help with the steps for a first time user. Do you have a online Manual for Wii Fit Plus activities?
There should be a manual in the box.
If not then just turn on the wii and the wii fit board, insert the disc and follow the onscreen instructions.
May 03, 2011 | Computers & Internet
I have used my wii fit plus 3 times with no problem but yesterday i did body test then went training first few games were fine then it started saying my weight was a little different than before do i want...
Yes, it's completely normal. To avoid this, try to take the BMI test at the same time everyday. If you have a big meal in between the weights, it might say that.
Also, the batteries on the board may be running low. Try with some new ones and see if the problem persist.
Also, try keeping the Wii Balance board on a flat hard surface, such as the floor. Do not use it on thick carpets since it might report bad measurements.
Hope this helps.
Aug 26, 2010 | Nintendo Wii Fit Plus for Wii
Hello, what is the max weight be to be able to use the wii fit?
Bottom line its :300LBS
Check out this link
http://www.gamespot.com/wii/sports/wiifit/review.html
Read Second paragraph.. Hope i helped
Sep 02, 2009 | Nintendo Wii Fit for Wii
I have just bought a wii fit and when it starts the synchronising process with the board an error occurs and I can't move past the screen as the remote control doesn't work.
Start from scratch, turn the system off then turn it back on. Start the wiifit game, when it asks for you to connect it, open the door on the frony of your wii and push the little red buttom, then push the little red button on your wiifit board by takinng the battery cover off and push the little red button and it should sync.
Jul 30, 2009 | Nintendo Wii Fit for Wii
Wii balance board weight differently after put on a wii board sk
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
Feb 26, 2009 | Nintendo Wii Fit for Wii
Want to use two wii fit boards at the same time?
You can't sync 2 balance boards to one wii.
I heard this is why but this isnt confirmed...
the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
hope this helps...
Feb 05, 2009 | Nintendo Wii Fit for Wii
Wii Fit - Hoola Hoop
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Feb 04, 2009 | Nintendo Wii Fit for Wii
While working out the system stops frequenty.
Note that the sensor bar does not interact at all with the Balance Board. It seems that you may have a defective unit. Since you have tried brand new batteries, my suggestion is to open a ticket with Nintendo through their website.
Feb 01, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Fit - Balance Board + Game Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
