Question about Edirol UA-1000 External Sound System
Cakewalk Sonar - Edirol UA-1000 crackles on playback!
I'm using Sonar 4 PE, an Edirol UA-1000 soundcard/input module, running XP on a computer that has well above minimum requirements.
I've done everything from downloading latest driver from Roland, uninstalling and reinstalling Sonar, maxing out the latency and the cache in Sonar (and on my PC!), and allocating every bit of memory to virtual memory and running programs, and I STILL get crackles on playback!
It's not as bad since I maxxed out everything (latency, buffer, etc), but there is STILL crackling on playback!
Any advice?
    Problem Solver:
  • 6 Answers
That's a latency issue it sounds like.
There's a slider under "Audio" .
Move it in increments towards "slow", test it as you go.
Leave it at the highest setting possible that doesn't crackle.
I've heard this so bad that it sounds like a gun going off.
It scares the Hell out of you when it happens !
Posted on Aug 29, 2010
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
Seem to have developed a problem with my audio recording and playback using Roland's FA-66 (Editrol). I use Cakewalk SONAR, Sony Sound Forge and Vegas Video softwares, and all of them show the same sound...
www.rolawww.scottyp-music.com/geardos/?p=21 nd.com/products/en/_support/dld.cfm?...FA-66
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
Nov 15, 2009 | Edirol FA-66 Sound Card
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Aug 30, 2009 | Edirol UA-4FX External Sound System
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Mar 17, 2008 | Edirol UA-4FX External Sound System
No sound out from input
It's probably your computer, more specifically the type of application you're running it on/in. Also, when you install or fiddle with the settings, you have to be careful because it can be so confusing fixinfg them.
Dec 12, 2007 | Edirol UA-4FX External Sound System
SONAR LE NO AUDIO
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Sep 04, 2007 | Edirol UA-25 External Sound System
Crackling noise - help
check all your cords make sure they are connected proper if they are then its internal. Is the gear brand new if so its under warranty if not then come back and ask again. It takes a brave person to answer your direct email address that means you are able to see who the person is ie his email address you will know. On fixya people dont like emailing others because the others maybe spammers....hence the Report abuse button on this program!
May 17, 2007 | Edirol UA-25 External Sound System
Edirol UA-1000 External Sound System Logo
279 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Steven Burn
Steven Burn
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
