Question about Whirlpool LER5636P Electric Dryer
Dryer Not Tumbling
Whirlpool Electric Dryer, Model # LEQ9508PW1-Dryer made a loud pop, the drum stopped turning, but the motor is humming. Spun the drum by hand, and dryer started working. This dryer isn't even two years old yet.
  • 296 Answers
Sounds like belt problems.
Posted on Jan 20, 2009
GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Dryer will not tumble Model, electric Imperial
WHEN YOU START MACHINE DOES THE MOTOR RUN OR DO YOU JUST GET A HUM?IF MOTOR RUNS THEN BELT IS BROKEN.REMOVE SCREWS AT LINT FILTER AND POP UP TOP ,SHOULD SEE BELT IN MIDDLE OF DRUM..IF IT JUST HUMS REACH IN AND TURN THE DRUM 1 REVOLUTION CLOCKWISE AND RESTART.IF IT STARTS MOTOR IS GOING BAD.HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool Dryers
WHIRLPOOL ELECTRIC DRYER.MODEL # LEQ9508PW1. DRYER IS NOT SPINNING. MOTOR IS HEATING AND RUNNING FINE. I OPENED TOP AND BELT IS ON BUT LOOSE. BELT IS NOT BROKEN JUST LOOSE. WHAT COULD THIS BE?
You will have to go farther and remove the drum.
I believe your problem is that the belt has slipped off of the motor, or has slipped off the idler arm with pulley brackett.
Good Luck,
I hope this helps
Oct 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer turns on - we hear the motor going - but the clothes do not tumble - the barrel isnt turning
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Turn it on and its not spining
take top off machine and give the drum a push by hand. if it starts and continues to run then the fault is the motor capacitor - cheap part
Jul 14, 2008 | Dryers
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
306 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
