Spots on faxes sending and receiving copies and prints look fine arm355n arfx12 fax unit
    Champion:
  • 320 Answers
Clean the scanner glass
Posted on Jan 20, 2009
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
It's not sending or receiving faxes, but line is working
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
micro
Jul 28, 2009 | Canon FAXPHONE L80 Laser
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
jasbo
jasbo
