Question about Weber Genesis Silver B Grill
I have the weber genesis gas grill #55826. What flavorizer bars do I need? I am replacing them.
I need the sku number for flavorizer bars that will fit in this grill
5 Suggested Answers
  • 333 Answers
SOURCE: how often do i clean the flavorizer bars?
I clean mine ounce a year
Posted on Jun 18, 2010
alpug
  • 1961 Answers
SOURCE: bought a weber genesis 320
1. Most US gas bottle regulators are set to 30mBar, Germany is usually 50mBar.
2. Most European gas fittings are a left hand thread. Although surprisingly they are often still have an English / imperial thread type (1/4" R is a common gas appliance thread type in Germany).
3. 30mbar gas appliances are still occasionally used in Germany, mostly imported from the US for use in a a caravan or boat.
Check the link below the replacement regulator for your Genesis E-320 to work with German gas cylinder.
http://translate.google.com.ph/translate?hl=tl&sl=de&tl=en&u=http%3A%2F%2Fwww.campingaz.com%2FDE%2Fp-25990-verstellbarer-regler-30-50-mbar.aspx
Posted on May 08, 2011
  • 4736 Answers
SOURCE: Bought a weber genesis 320 Problem with the Weber
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
mark24354
  • 776 Answers
SOURCE: I replaced the porcelain enameler flavorizer bars
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
Posted on Jul 16, 2011
What is the steel production at Columbus Stainless Steel?
to know more about it visit
http://instinox.com/steel-pipes/
Dec 09, 2014 | Weber-Stephen Products Weber Genesis...
My weber grill doesn't seem to be getting enough gas thruogh the jet to heat to proper temp.
The most likely problem is that food drippings have clogged some of the pin-hole gas outlets in the burner tubes. If those are clean and open, then either your propane tank is not releasing the gas or the controls on the grill are not releasing the gas. If you look at the flame level, probably best done with the flavorizer bars removed, and they are all the same with the controls on high, then it it probably the tank valve. If the flame heights are different, the lower one(s) are the ones where the control valve(s) are not working and need to be replaced. Good luck!
Jul 25, 2011 | Weber Genesis Silver C Grill
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
Jul 16, 2011 | Weber Genesis Silver B Grill
Does not heat up right
Disconnect tank - remove cooking grates and flavorizer bars - use a soft metal brush and lightly brush the burner tube (where the flame comes out) and make sure they are not clogged up. While you have the grates and bars out you should clean them as well with hot soapy water and a brush. Put all pieces back in when done cleaning and re-connect the propane tank. Open propane tank valve 1/3 of a turn and light grill. After it ignites, open valve further. Usually a good cleaning will take care of it. If not, it may be the gas regulator. Weber has great customer service and will be more than glad to help you with just a phone call. On your grill there should be a label showing your model and serial number. It is very helpful if you have this info if you call Weber (but not totally necessary). Weber contact number is 1-800-446-1071
Apr 24, 2011 | Weber Genesis Silver B Grill
Have a 15 year old Weber Genesis. Recently filled the tank, and was working fine. Today, went to fire it up and barely any flame coming out of the burners. In fact, when I turn on the middle burner, the...
You need to completely change the grill because it's been there for over 15years and alot of rust and linkages will after affected the grill from working properly well.The best bet is to get a new grill.
Nov 25, 2010 | Weber Genesis Silver B Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Aug 06, 2010 | Weber Genesis Silver B Grill
Should there be fake coals in my gas weber bbq
Get rid of the fake coals they will only collect grease and cause a fire.
Jun 29, 2009 | Weber Genesis Silver B Grill
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Weber Genesis Silver B Grill Logo
453 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
