Question about American Standard Heating & Cooling
American standard condensing unit is kicking breaker
Kicking breaker
5 Suggested Answers
daddyo742001
  • 70 Answers
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Posted on Jun 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: American Standard Air conditioning unit Model 2AGB0036A1000AB
Hi I am sure this model number is correct and it is a 3 Ton unit.Normally when the breaker trips as soon as you reset it, the compressor is compromised. Happened to me yesterday on a 5 ton heat-pump. When this happens, what you can do if you are a handy type of man, is to prove this. I don't know if the is is a split system or a all in one package unit, doesn't matter. Get to the compressor compartment. Of course the power will be off.If you can see the run capacitor, take a screw driver and short across the terminals to discharge it, as it could have a small amount of juice in it, I doubt it. Anyway, remove the plastic cover to expose the terminals. They can be hard to remove sometimes, just use a screw driver to push the clips in. Wire colors should be black for common, yellow for start, and blue for run. Write down the order they were in. To be safe, tape the metal connectors so they wont touch metal when you turn the power back on. After you have done this, turn everything back on. If the breaker holds and everything else is on, fan and so on, this proves the compressor is probably shorted to ground. If this a/c is rather new, I would replace the compressor. If it is old, I would think about getting prices on a new unit. Just food for thought. Please let me know on the out come of this test, please. When a compressor shorts out, or locks up, it draws what is called locked rotor amps/LRA which could be from 49 on up, and your breaker can be 25, 30, 35 to 40 amps so it will trip. Keep me posted and do this test, it is very easy to do.
Sincerely,
Shastalaker7
Posted on Apr 18, 2010
TX_AC_Man
  • 107 Answers
SOURCE: do bryant condensing units have
Most Bryant units do not have a reset button but could have a low pressure or high pressure switch for a safety to protect the compressor. Verify power from the thermostat to the contactor by following the thermostat wires all the way to contactor inside of electrical compartment... TURN POWER OFF BEFORE OPENING.... If power is to contactor and contactor is pulled in then you would need to look at the capacitor of which is a canister about 6 inshes tall with wire terminals on top.. this part should be flat on the top and if it is rounded then thats your problem.. if not then contact a local company to troubleshoot and make necessary repairs.
Posted on Sep 01, 2010
  • 119 Answers
SOURCE: The circuit breaker for the
It is tripping for one of two reasons. Either the a/c unit is pulling too many amps or the breaker is weak. If you have an amp meter then check the amp draw on you a/c, if it is pulling more than 24 amps then you need to have it serviced. If it is not pulling that many then you have a weak breaker and need to replace it.
Posted on Jun 28, 2011
I have American standard heritage 11 heat pump with the coils inside btw it's a double wide I was wondering where the fuse might be located
There will be a box that the unit gets power from, either up on the roof or on the side of the home, the fuse or circuit breaker will be in there.
Jul 18, 2016 | American Standard Heating & Cooling
Carrier model 38tdb air conditioning unit kicks out the 40 amp breaker. Also moisture under compressor unit outside. What is problem?
What breaker? The breaker for the condenser? Likely have a compressor shorted to ground or drawing locked rotor amps. Easiest way to tell is make sure breaker off, unhook compressor wires from contactor. Turn on breaker and turn on machine. If the breaker does not trip, obviously problem with compressor
Jul 14, 2016 | Carrier Heating & Cooling
Outside unit will not come on but has power. furnace fan comes on. what might the problem be?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
May 28, 2016 | American Standard 5000 Heat Pump Unit
American Standard heat pump troubleshooting
If the compressor is not frozen, then it is most likely one of the starting capacitors on either the compressor or the fan motor. These can fail without warning and without any outward indication. They are shaped like small cans or oblong cans and have 2 or more wires that attach to them with terminals. If you are going to remove one or check them, Make sure the power is off first.
Aug 11, 2014 | American Standard 282999 4" Heat Pump Snow...
The circuit breaker for the outside unit of an American Standard central AC system started tripping and when reset only runs for about 15 minutes before shutting down again. It just started doing this...
Jun 28, 2011 | American Standard Heating & Cooling
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
Inside Electric Furnace/Air Handler Not Working. Please help!
ok this can be simple or tricky is the breaker that trips the same size as the one in the breaker panel 2.look in the unit itsself see if there r breakers inside the unit there usually are and they might have tripped it might be as simple as flipping a breaker but the problem with the breaker tripping is what concerns me now it may just be undersized or getting weak and finally crapped out get ur meter and flip the breaker on and see if u r getting power to the unit if ur not u have gott a breaker that isnt letting power go thru now if u have power u might have a bad blower motor turn the unit on and calling for the fan on if the fan doesnt start try spinning the blower by hand now if it starts then u probably have a bad capacitor they r usually mounted on the side of the blower housing it is oval and its gonna be a 5mfd(microfarad) or 7.5mfd and that couldve been what was kicking the breaker now if the blower is stuck and it wont turn or its very hard to turn then make sure the blower wheel hasnt slipped on the shaft and is rubbing up against the housing if it is just loosen the set screw and set it back even and tighten it back up now if the wheel is free and its still hard to turn then u have a bad blower motor its not a big deal to change out and not real expensive if this dont help hit me back and well walk thru it hope this gets lil momma and the pets warm have a good day
Feb 26, 2010 | Heating & Cooling
All of a sudden, no hot water. No red light....what to do? Already checked the breaker.
Bottom heating unit is probably burned out from overheating due to sediment in bottom of tank.
Feb 26, 2010 | AMERICAN STANDARD Electric Water Heater
Jun 28, 2009 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
