Question about JBL Platinum Series Speakers 3 Watts/channel
Where is the volume control on the JBL platinum series speakers
5 Suggested Answers
SOURCE: JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Posted on Jun 26, 2009
SOURCE: JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Posted on Feb 22, 2010
  • 377 Answers
SOURCE: Where can I download a
just visit this website http://www.jbl.com/Pages/LocaleSelector.aspx
Posted on Aug 12, 2010
jim4984
  • 797 Answers
SOURCE: w4e were given jbl speakers
You should not require an drivers. The speakers should just plug in an work. Note that almost all computer speakers need external power to get an volume out of them. Some may output a whisper without power but most just remain silent. The output of most audio cards in computers are designed to drive mini headphones like an iPod or other MP3 player.
If you are having a problem with the speakers, please explain in detail the problem.
Thanks, Jim
Posted on Jul 04, 2011
My JBL Platinum Series speakers are not operating;they did before I took the PC into the tech support agent
Try reinstalling the audio drivers on the disk that came with your machine. If you dont have a disk then download from the make of the machine.
Aug 25, 2010 | HP JBL Platinum Computer Speakers
No sound from speakers
Probably.
Do they connect to the computer via USB or mini plug?
If mini plug, make sure you have the right jack on the back of the computer (there's two)
Then go into System Preferences ... select "Sound" and see if you can select something other than "Internal Speakers" - the computer may just not be aware that you want to use the external speakers ...
Are the speakers powered? Is there a volume control on the subwoofer, or an external fob with a volume control on it? You probably know this if you used them previously with your Compaq computer ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 11, 2010 | HP JBL Platinum Computer Speakers
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
MY JBL Platinum Series speakers work on one side
the first thing to establish whether its the speakers would be to try them on a different computer. If there is some sound, that means its getting some feedback. Maybe you could go to sound manager in your control panel, or on the volume menu that you can access by clicking the volume icon on your desktop taskbar, you know, by the time and stuff. Once there, adjust the balance by moving the slider all the way to either side to see if its unbalanced. You might also wanna adjust the sound scheme from mono to stereo or dolby digital which would be in the same menu/ window. Does the right speaker thats plugged into the tower have a balance (R)ight and (L)eft? you might also want to adjust that to either side. If that is not helping, maybe there is a hardware issue with the left speaker, maybe a short, or a problem with the wire and you might have to replace that speaker if you do not know how to fix speakers. Tell me how everything works out.
May 25, 2009 | HP JBL Platinum Computer Speakers
Needed watts and voltage of JbL 5000 series platium speakers
If you have one already, just check the wattage on the power supply.
Feb 28, 2009 | HP JBL Platinum Computer Speakers
Where can I find JBL platinum series speaker drivers?
Hi!
The kind of speakers usually don't effect what drivers you have to use. If you have your motherboard cd then you can install the sound drivers from that cd. And, if you still are unable to find them in the cd then please tell me the model no. of your PC(and/or model no. of the motherboard).
Please rate this solution as FixYa if found useful.
Thanks Rylee
Feb 20, 2009 | HP JBL Platinum Computer Speakers
Speakers
mi JBL platinum serie do not work in another computer is name is Super Power
Aug 20, 2008 | HP JBL Platinum Computer Speakers
JBL Platinum Series speakers won't work pls help
reinstall the audio driver for vista,and then use the speaker it will works
Aug 15, 2008 | HP JBL Platinum Computer Speakers
Compaq JBL Platinum Series speakers
Make sure that you got 12v 1.0 A adapter. Not .01 A. They have one at newegg.com atrix DVCPA1AA power adapter-12v 1.0 A. you should not need drivers for speakers. Make sure you got it pluged into right port if you got the adapter. Also make sure under control panel under sound that you got it setup for two speakers.
Jun 29, 2008 | HP JBL Platinum Computer Speakers
JBL Platinum Series Speakers 3 Watts/channel Logo
70 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
