Question about Toys
Won't back up. just stops, no grinding noise . second jeep sounds to be slipping gears in high and low, forward and reverse. Help
  • 350 Answers
May be rusted!
I'd buy a can or two of WD 40 or similiar lubricant and spray it all over all the rusted metal I can get to then turn the wheels by hand as much as possible but that's just me!
Good Luck!
Posted on Jan 20, 2009
V70 poured new Dex3 auto trans in. Reverse gear stops working after a few days equal 500km, but all forward are still ok.
Sounds like your transmission is going bad. If your transmission is slipping only in drive or forward gears, then it could be just that it is low on fluid, but when reverse starts to slip it usually means rebuild/replace transmission.
Good luck
Dec 02, 2013 | Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Mar 27, 2013 | 1995 Land Rover Discovery
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
WHen under load the motor revs up and it seems that the Clutch is slipping, it has 100000miles and I suspecting the clutch or the high / low range might be messed up, its a 4 plus 3 manuel transmission.
If it feels like the clutch is slipping, chances are it is. If there was a problem in any component that has internal gears, you would have grinding noises. Gears cannot slip. As the clutch wears more you may hear grinding when you try to change gears but that is because the clutch won't fully disengage so the gears are spinning too fast to shift properly. Before that happens, have the clutch replaced.
Aug 02, 2011 | Chevrolet Corvette Cars & Trucks
My 93 Wagoneer is 4WD all time. Pulled into town doing about 35mph and heard a loud knock. It would do it a few seconds after taking off from a stop and when It would try to shift. Before I could get where...
Sounds like the fluid coupler inside the transfer case failed. In my opinion using those is a great idea
on paper but they just do not last as well as the older direct engagement units used in Cherokees and wranglers. I own many Jeeps and will not have a GC for that one reason.
The transfer case needs to be removed and rebuilt. There is no external repair or temporary fix.
Dec 28, 2010 | 1993 Jeep Grand Wagoneer
Very slow to kick in to reverse, first and second gears accompanied by high revving sound. Not a smooth transition to other gears as well. High revving until going. Very high fuel consumption as well. Once...
it sounds like your transmission is slipping. they make this chemical you can get at a part store, its a transmission stabalizer. it should help with the grinding noise and transitions to the other gears. also give your truck a complete tune up (oil change, fuel and air filters, spark plugs etc.) it should help with the fuel consumptions.
Aug 13, 2010 | 1997 Chevrolet S-10 Pickup
4x4 slips shiftin gears starting and stopping
you might already know but when shifting into 4wd you can shift into 4hi while driving as long as the tires,(all four) are travelling the same speed. you can't shift into 4wd if you are spinning. 4 low you have to completely stop. When you are in 4 low as you know the power of vehicle is greatly increased due to gear reduction. so if you are seeing slipping symptoms, you might want to change transmission filter. It might not be much help to you but it might prevent problems down the road. also when changing fluid be sure to put mopar transmission fluid for replacement on jeep. like gm calls for dexron. the transfer case on dodge and jeeps also takes transmission fluid. I had to replace a t-case on my friends dakota that was making a grinding noise and it turns out a seal had leaked some fluid out and burnt up some bearings. pretty expensive. they are chain driven. hope I didnt get too carried away, because I am not a transmission expert but I just wanted to share what I did know with you.
Jan 12, 2009 | 2000 Jeep Grand Cherokee
01' F-250 SD noise in trans
have the transmission rebuilt sounds as if drive gears are wore out.
Oct 09, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Toys Logo
120 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
