Question about Dometic Refrigerators
Replace inlet valve kitchenaid sub zero kssc42qms01
3 Suggested Answers
  • 71 Answers
SOURCE: Describe how to replace a solenoid valve on a subzero 532
easy.. disconect power . important. remove the kick plate. the water valve is locate in the left side. its a blue color. inside a bracket or attached whit 2 screws ( depend on the serial break) remove the water valve from bracket. disconect the plug and the and the line and thats all.............................................. NOTE. MAKE SURE TURN THR WATER SUPLY MOST LIKELY IS THE COOPER LINE . CLOSE FROM THE WATER METER OUSIDE YOUR HOUSE OR CLOSE TO THE WATER VALVE....... DO NOT TRY TO REMOVE THE FRIDGE.............. good luck... LEAVE YOR COMMENT IF IT WAS GOOD FOR YOU... THANKS
Posted on Apr 02, 2010
imufo2
  • 3773 Answers
SOURCE: sub-zero model 590 - replace
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 21, 2011
WATER DOESNT SHUT OFF AFTER ICE CUBES ARE MADE- THEN THE CUBES BECOME ONE SOLID BLOCK FROM THE DRIPPING WATER. SERVICE GUY SAID NEED TO REPLACE THE ICE CUBE MAKER: STRANGE THE ICE CUBES ARE PERFECT -...
Replace the water inlet valve to the unit. The valve is not closing completely after the water is called for. By replacing the valve should solve this issue.
I hope this helps.
Sep 12, 2013 | Sub-Zero Refrigerators
Holiday mode refrigerator
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Jul 24, 2013 | KitchenAid KSSP48QMS Side by Side...
My sub-zero 245 has a build up of frost behind the ice maker bucket, the vent has about one inch build up of frost . The ice cubes are almost clear?
HI.RON.i think this has to be in stages.1-defrost evvvvverything first 2-turn off water supply.if this cure the problem the the fault lies on inlet valve(leakig over)try.good luck
Jun 19, 2012 | Sub-Zero 245
The ice maker won't stop dripping.
The problem is going to be the water inlet valve isnt fully closing and seeping water through it all the time. To fix it the water inlet valve would need to be replaced,typically on all Sub-Zero brand refrig's the valve will be up by the compressor in the area above the ref. behind the top grill.
Also while up there replacing the water inlet valve be sure to clean all the dust from the condenser coil as well as replacing the water valve.
GENE
Sep 06, 2011 | Sub-Zero Refrigerators
I replaced my ice maker and it is still not making ice. I have yet to find the inlet water flow to ensure it is getting water. Could another inlet valve be witholding water from the unit?
water valve is under neath in the left cornor . remove grill to see. freezer must be 15 deg or colder to cycle . so ck the tempt first then look at valve . ( valve if butned out will be problem . ck valve with ohm meter . .but its dificult to ck for voltage . mm
Nov 01, 2010 | Sub-Zero 642
The ice maker in my sub zero 695 is not working, what may be the problem? and where can I buy the bulb for the lcd indicator?
NORMALY ITS THE INLET VALVE THE WAY I CHECK A VALVE IS HOOK 110 VOLTS DIR TO IT IF WATER COMES IN IM THE IM MAKER ITSELF IS BAD
Nov 06, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker won't work
Check that lines are not frozen.
Check the inlet at the back of the fridge, ensure is not blocked.
Defrost unit completely to ensure it is not a frozen lines problem.
Check icemaker inlet valve, solenoid, and mechanics.
Here diagram and parts for your fridge's icemaker.
May 20, 2009 | KitchenAid Refrigerators
Refrigerators Logo
47 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
