Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher KUDSO2SRWHO won't start.
The right cycle lights come on but nothing happens. Start light flashes.
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
  • 1015 Answers
SOURCE: my KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Posted on Sep 26, 2009
  • 1382 Answers
SOURCE: dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Posted on May 17, 2010
How do I reprogram the start, rinse cycles? snowflake is blinking and nothing happens when I try to start washing.
[PDF]Download Bosch Dishwasher-Manual - DASH Property ...
www.dashpropertymanagement.com/.../Bosch-Dishwasher-Manual.pdf
Lift tab to open the rinse aid reservoir and add -3 tablespoon max, do not overfill. "qUid rinse aid ... Cancelling a cycle I Reset the dishwasher. 0 LEDs flashing ...
[PDF]Dishwasher Use & Care Guide EIDW6105G - Datatail
media.datatail.com/docs/manual/40243_en.pdf
We view your purchase as the beginning of a relationship. ... Store dishwasherdetergent and rinse agents .... This cycle allows you to program your preferred.
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
https://www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR
KITCHENAID DISHWASHER REBOOT ... Dishwasher Repair will not start - Repair & Diagnostc - Kitchenaid - Whirlpool ... What toDo When the Dishwasher Won't Start - Duration: 5:43. by doityourselfstan 217,315 views. 5:43 ... KitchenAid & WhirlpoolDishwasher - Not Cleaning ,pump wash arm impeller ...
Dec 16, 2015 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
KUDI02IRBS Kitchenaid dishwasher won't start cycle
Perhaps the child lock is on. Push and hold the heat/dry button for 5 seconds and hopefully the keypad will be unlocked. Hopefully that will work for you.
Mar 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
42 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
