Question about Husqvarna Garden
Husqvarna l65 oil adjustment - Husqvarna Garden
3 Suggested Answers
SOURCE: Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: Where is manual oil adjuster on a Husqvarna 2100 chainsaw
This saw?
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/e833e76f0bf8658788256b5200199012?OpenDocument
Is so long of tooth there are no on line manuals available.
Please contact Husqvarna here to request an OM.
http://www.husqvarna.com/us/homeowner/support/customer-support/
If you mistyped the model number please reply with the correct model and serial numbers below. HTH
Lou
Adjusters are normally underneath, directly under the clutch.
Posted on Feb 20, 2010
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Hello, i have an old L65 Husqvarna chain saw, i have been lookin for a piston kit, but with no luck, i was told that old style 48mm piston out of Husqvarna model 61 will work in a l65 . Can any one co
I have a homelite piston running in my Husqvarna edger . Most pistons for engines are all the same if the cc's are the same . they only vary in the gudgeon pin size and the location of the pin in the piston. So take your piston to a small engine wreckers and any piston that measurers the same ,looks the same will do the job. then get a new piston for the make that it came out off and it will fit.
Mar 28, 2014 | 1993 Nissan Pathfinder
Husqvarna 235 is leaking bar oil really bad
Hi, What Kind of oil do You use? A thiker one could be a solution.
Usualy there a other screw (than those H and L of the carburator) to adjuste the amount of oil spend on your blade.
Feb 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Cannot find adjustment oil screw on my Husqvarna 61 Chainsaw
The 61 has a 4 position oil pump, the adjuster is a black plastic screw located to the top right hand corner of the pump face, just behind the sprocket, you will have to clean around that area to find it. The pump has numbers 1 to 4 around the screw, 4 being the highest position.
May 19, 2012 | Husqvarna Garden
I have a husqvarna 435 and its not oiling, is there an adjustment skrew anywhere? thanks
There is no oil adjustment on the 435 and these saws have bad oiling systems( leak oil badly when not is use and don't put out enough when running) , bad enough that it damages the bar and chain. The only solution is to use 30 weight engine oil ( bar oil is to thick). Crummy design.
Jan 27, 2012 | Husqvarna Garden
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
This saw?
Lou
Feb 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can chain oiler on husqvarna be adjusted as the oil is just flowing through
you can not adjust the oil pump it helps to use the right oil
Jun 19, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
78 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
