When i shift from 4x4 to 2x4 is feels like something hits hard and boom its back to normal 2 wheel drive. i had the fluid changed in both differentials and transfer case. It still does it, but when i shift from 2 wheel to 4x4 its fine. is that the way its suposed to be?
SOURCE: ford explorer 1998 2 door transfercase problem
did you put it in nuetral then switch it, wait a few seconds then put in reverse and back up a couple of feet and nuetral again, i had to do this on my explorer sometimes.
SOURCE: 1993 4l60e - Shifts hard on the 1-2 shift, works fine otherwise.
Did you change the transmission filter and gasket as well as the transmission oil before running your truck.
SOURCE: the transfer case will not shift into 4 wheel hi
I would suspect the vacuum disconnect motor or the vacuum solenoids for the disconnect motor ( or the vacuum lines ), but best to confirm
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
With the engine running ( and wheel chocked, parking brake on ) have someone shift into 4WD, and watch the shift motor to see if it operates
It is on the front axle, looks like this
If the disconnect motor does not shift, you can check the vacuum on the lines with a vacuum gauge. Blue line is 4WD operation, pink line is 2WD operation.
The vacuum solenoids are on the firewall, and look like this
This is the block diagram for the ESOF vacuum operation of the disconnect motor.
This is assuming you have checked the fuses for the transfercase shift motor, and the vacuum solenoids.
SOURCE: stuck in all wheel drive
check the fluid in the differential case. Also when the filter in the the differential case becomes dirty/clogged it will cause tis problem.
