Question about Kenmore 24032\24036 Top Load Washer
Agitator not working properly
I have a kenmore elite model#23032100 serial#cm2333592 type 111 and when my washer agitates it acts as if it is skipping.It is also clicking when it does this.All other cycles are fine.It is also dimming the lights in the laundry room when it is in the agitating cyle but not when any other cycle is being used.It didn't trip the gfi plug either..Please help...I can't afford to call the sears repair man.
  • 61 Answers
Remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Posted on Jan 20, 2009
  • 63 Answers
Sounds like you have high and low speed at same time to motor need its the timer,speed selector switch or motor need repair tech
Whirlpool type 111-05 Top Loading
The electronic timer is worn and requires replacement, this would be a bulky metallic box located just behind the large setting knob.
Dec 22, 2013 | Washing Machines
Kenmore Washer Will Not spin
replace door switch ,good luck APPLIANCES R EN
Mar 03, 2013 | Kenmore Washing Machines
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
How do I replace the dog agits on my kenmore Elite 23032100 washer?
The following link explains how to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you have any questions, please let me know. I hope this helps you.
Jul 08, 2009 | Washing Machines
Washer Won't Agitate
It might be the agitator dogs. Try to replace those
Feb 06, 2009 | Whirlpool LSQ8543J
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer not agitating properly
pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
I would make sure that the washer is properly leveled, and ensure that all sensors that check if the door is closed are working properly.
Sep 07, 2007 | Estate TAWB600JQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
504 people viewed this question
Sal De
fordexpert
Robert Rankin
