Question about Eureka Vacuums
Eureka surfacemax 200 not picking up - Eureka Vacuums
2 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: how to change a broken belt on a eureka surfacemax
Here is some info that will help:
You need this belt:
Eureka SurfaceMax 300 Belt
This is the manual with instructions:
Owner's Guide
Posted on Jan 02, 2010
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Smells hot when running and will not pick up debris I recently cleaned all filters
Something is stuck in the piping system. The passing vacuum air is used to cool the motor. It's not getting that air so it will start to over heat and smell
Jan 09, 2014 | Eureka Surfacemax 200 Bagless Upright...
Is the replacement belt supposed to be really tight?
Yes.
Put it on the back first.Then on the brush.Put the brush in belt side first then pull the other end in place.
Jul 12, 2011 | Eureka Surfacemax 200 Bagless Upright...
I need help to locate the belt on the vacuum please
flip the vacuum upside down and take cover off might need a phillips screw driver belt should be there on the brush roll once you remove the lid
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
My son vacuumed up water. I am trying to open up the cannister & dry out, but am unable to get at all the screws. Is there a manual available that would show how to get at all the screw locations?
you will need a flat screwdriver and a little patience to get to the screws.
you will want to remove both the switch cover and the cord retract cover to get to the screws. once you have done that, you can get into the motor chamber area and dry that unit out.
Good luck,
Mark
Nov 06, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
How to change a broken belt on a eureka surfacemax 300
You need this belt:
Owner's Guide
Jan 02, 2010 | Vacuums
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Vacuums Logo
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
