Fallo "err 1" lavadora Teka TKE-1200 T - Washing Machines
4 Suggested Answers
  • 1416 Answers
SOURCE: I have a Teka TKE
This code refers two 1 of 2 things first is the electronic touch pad that has shorted out OR some time an indication of over flow of water in to the panel indicated by the sense sensor and needs to be replaced so have this checked first next is the electronic control circuit or ecc for short or need a little service .
some models the touch pad is part or panel of the ecc okay.
You should remove the touch pad or the ecc and have them tested at any appliance parts center if you have one in your home town or get a better one from the store around your local area
If your oven still has the warranty this will be covered under this okay
Hope this is very helpful for you?
Thank you and thanks for using fixya.
Posted on Oct 15, 2010
SOURCE: tengo un problema con mi lavadora whirlpool duet
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Posted on Jun 01, 2010
  • 6277 Answers
SOURCE: Please help me as whenever
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 15, 2011
Error 1 in teka washing machine 1260 WD. What does it mean?
code E1 Main electronic control board failure Unplug the washer. Check the wiring connections on the main electronic control board in the console. If the wiring connections are sound, replace the the main electronic control.
Nov 07, 2014 | Washing Machines
Teka freezer
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other.
if you provide your model number then it might be a special case. here is user information on one model Teka.
http://www.fridge-manual.com/teka/teka-tki2-325.html
Oct 02, 2013 | Jenn-Air Refrigerators
Teka tkx 13wd manual
I`M Korean, I need a 'TEKA tkx 13Wd manual. Please, so hard usually to TEKA washing machin...
My E-mail is
key00519@naver.com
Thank you.
Aug 11, 2013 | Washing Machines
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
Please help me as whenever i switch on the teka washer/dryer the electric trips. The model is: TKE 1260 WD
John C
Jul 15, 2011 | Washing Machines
Will not tke picture an err message flash at top of screen
Hi anotherie14, the ERR is not a good thing. Try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go to Nikon.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need a manual for a teka washer/dryer A ls13
We have a Teka washer/dryer A-L512 1200 and all the clothers are comming out with fluff on and the dryer takes too long to dry. We can't find the filters, where are they?
Jul 15, 2009 | Washing Machines
Washing Machines Logo
357 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
