Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
HDMI port does not work on the KV-30SH420
I have a new Blu Ray and wanted to connect it via a HDMI cable.  I have placed the cable correctly and set the TV setting to 7 and the screen is just black.  I tried other HDMI devices and none work.  I do not think it is the cable.  Any suggestions would be cool.
Dane
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Posted on Jan 20, 2009
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
No video via hdmi from blu ray
Have you attempted swapping out the HDMI cable for a different one? I recently had a similar problem and I determined that the HDMI cable was faulty. Now everything works fine.
Jul 26, 2012 | Televison & Video
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia...
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
HDMI Video not working on kv-30hs420 but audio works
AmigaDude posts how to reset the video to factory settings here: http://www.avsforum.com/avs-vb/showthread.php?t=766771
The instructions are as follows: 1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Once reset, you'll connect your RCA cables (Red/White/Yellow) and set up the PS3 display settings. To get there from the XMB bar, go to Settings > Display Settings. You might have to disconnect the HDMI cable from the PS3 before the RCA cables work. I don't remember entirely.
Select Video Output Settings > HDMI > Automatic. If you can see the prompt about a max resoultion of 1080i (with your HDMI cable plugged in) you should be good. Select Yes and press X to continue. You can set up the audio but it's not necessary. Select Finish and you should be good.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
425 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
