Question about Miele ART S920 Bagged Upright Vacuum
Miele Mistral S7280 won't run after changing the bag
Today I vacuumed, and noticed that the bag needed to be changed, so I changed the bag and closed the door. Turned it on and it won't run! The headlight turns on but the motor doesn't. I readjusted the bag but it didn't fix the problem. There was no blockage or over heating. Looked in the manual and it says nothing about this problem, also searched all over the net but can't find an answer. Please help!
  • pinkrock Jan 23, 2009
    Thank you, but yes, the carpet mode is on and there is no blockage at the roller brush. It's not that the brush won't turn, it's that the vacuum won't turn on at all...other than the headlight...the motor is not turning on. It's a new unit and this is the first time I changed the bag. It worked fine before I turned it off to change the bag but once I changed the bag and closed it up and switched the power button back on...nothing but a headlight came on!
  • Anonymous Mar 16, 2014
    bag bracket
  • 328 Answers
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
Posted on Jan 23, 2009
  • Ryan S
    Ryan S Jan 23, 2009
    How strange! Make sure all the filters are in correctly seated - sometimes Miele have a knack of making machines that have a failsafe - if the filters aren't in properly - the machine won't start up. Failing that, it may well have to be returned and with such a vacuum like this thats so brand new you will be in your rights to return it.
My miele vacuum hazard lite is on why? it won't function
change the bag, only use genuine miele bags, make it's fitted correctly & hatch is fully closed.
Apr 21, 2017 | Miele Vacuums
Why does it have little to no suction power on carpet?
either your hose is stopped up or your motor is going bad and doesn't have enough power, first clean out your vacuum and check belts and make sure they aren't worn out and broken or stretched
Dec 13, 2015 | Miele S7280 Bagged Upright Vacuum
I am looking for a parts diagram for a Miele Upright S7280 (Salsa) vacuum
See if there is a manufactures web site and inquire if diagram is available or just Google for info with proper make and model.
Fist just search for vacuum diagrams then refine search for your vacuum but this not always easy can be confusing so might have to take it to vacuum repair business or if you have not dissembled it yet just make notes when you do. Its not as hard as it seems I have done it many times.
Oct 24, 2012 | Miele S7280 Bagged Upright Vacuum
My miele has no suction and i changed the bags
99% of the time you can fix this problem with a new filter i have put the link in for the filter for your vacuum cleaner if you have changed the filter in the last 3 months then you might have a blocked hose check the hose first then get yourself a new filter
Miele filter for s514
Jun 04, 2012 | Miele S514 Solaris Bagged Canister Vacuum
Popped the lid open to change vacuum cleaner lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Miele vacuum dust problem
Hello. The problem you are having can be rectified with the new Miele FJM bags.
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
May 24, 2010 | Miele S4210 Carina Bagged Canister Vacuum
Dust compartment lid won't close
Hi Depending on the filter you have, you need to check that the filter grid has been securely locked in at the back. Check that it "snaps" down and locks into place. Then check the position of the bag. If the bag is sitting on the rising bag lock slider then the hinged slider needs to be pushed down into the bin. Usually the lid will close and lock down if you remove the hose. Try this to see if it works. Then check to see that the bag is opened out where the hose usually goes - if the mouth of the bag (and this also includes the new HyClean range with the seals already built in) looks out of angle then it has slipped upwards. This usually happens if the bag hasn't been folded out properly and can take milliseconds to put right.
Then put the hose back in and lock into place.
Has this solution been Fixya? Please rate accordingly or msg again if you need more help.
Mar 28, 2009 | Miele S4580 Luna Bagged Canister Vacuum
Miele ART S920 Bagged Upright Vacuum Logo
940 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
