Question about Electrolux Vacuums
Can't remove motor cover for electrolux EL2050
Is there a trick to romove the main cover of an electrolux EL2050?
  • 32 Answers
Usually there are screws on the bottom, normally 6-12 screws. Once they are out, there may tabs on the outside of the base fram, lightly use two flat head screw drivers and pull the cover away from the base.. be gentle as this plastic is thin, and could break. You will also need to make sure that the handle assembly is in the down position as the cover can get caught up in the handle when you try to remove it.
Posted on Jan 20, 2009
I have an old AP 200 Electrolux Canister Vacuum cleaner. Can,t figure out how to take it apart to check the main switch & motor. What is the trick to getting it apart?
The whole thing comes apart like a puzzle. The side rubber pieces on each side slide outward to front of machine. After they are removed everything comes apart. Make diagrams so you will not forget how to put back together. If you need any more help, let me know. GOOD LUCK FRIEND.
Sep 12, 2014 | Electrolux Vacuums
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
I am having a problem getting one of my brushes off. The other 2 came off very easily. Is there a trick to romoving them? Also, do I use the knaplifters before or after shampooing?
This is the Floor Pro for those wondering.
Generally, giving the brushes a quick tug with a counter-clockwise twist will get them right off.
The naplifters can be used either way, but generally are used after shampooing. Be aware that if you happen to have Berber or any looped carpet, absolutely don't use the naplifters. (I hate Berber!)
For best results, use naplifters, vacuum slowly, shampoo (1 cap of shampoo per line of water), use naplifters, allow a couple hours to dry, vacuum slowly. Vacuuming slowly removes the maximum amount of dirt from the carpet and even under pad.
Sep 18, 2010 | Electrolux Guardian Bagged Canister Vacuum
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
How to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Dec 05, 2009 | Electrolux Vacuums
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Motor shaft wont turn on EL2050
Have you tried running the brush motor without a belt on it? Does it not spin without the belt? If so, you may have worn motor brushes (not too expensive parts, but make sure you order both brushes, or make sure they are sold as a set). If your motor is in good condition (you can check the brush motor by hooking it up to a momentary power source NEVER apply constant power to a motor that is not mounted to either the machine or something to keep it from running away) There is sometimes a switch down towards the brush head assembly that could be bad.
Jan 19, 2009 | Electrolux Central Vacuum
Vacuums Logo
144 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
