Question about Disney 13" TV
Black rectangle on screen
While watching television a black rectangle appears and covers the bottom half of the screen. It goes away if you hit a button on the remote, but then reappears.
  • 30 Answers
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Posted on May 01, 2009
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Black Rectangle appears on bottom half of screen
Go into your setup menu and turn off closed captioning. The box is there for some channels even though no text is being sent. If you need to keep the closed captioning, try selecting a different mode for it.
Sep 15, 2008 | Toshiba 24AF43 24" TV
Blach rectangle bottom halfpart of screen
Salutations bachiche13,
It sounds like your "Text" feature of your closed captioning may be activated. It sounds like what you would want to do is go in to your television menu and select CC or Closed Captioning to mute or off.
Hope this helps.
Jon
Go Ahead. Use Us.
May 21, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
DX-R20TR 20" Round TV/DVD Combo
I'm guessing its the "CC", closed captioning. You have to turn it off, it's either in your menu or you have a button the remote saying either, Text or CC.
Apr 07, 2008 | Dynex DX-LCD37 TV
Black rectangle
If the black rectangle is in the middle'please check to see that the closed caption is not activated.If not please provide the location of the rectangle.
Jan 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Black on lower half of screen
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Aug 23, 2007 | JVC AV32F577 32" TV
Disney 13" TV Logo
163 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
