Question about Transcend TS-RDF8K RDF8 USB 3.0 Flash Card Reader TS-RDF8K
Transcend ts-rdf8k USB 3.0 device not recognised
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: My Transcend portabable hard disk is not been recognized
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be followed.
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
5. always use the same port for connectin your devices. Some devices do not like being switched about.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Posted on Aug 23, 2009
  • 32 Answers
SOURCE: after 3 weeks of working fine my transcend
Maybe the USB or the connection where you plug it in is messed up see if you can replace it
Posted on Dec 16, 2009
  • 43 Answers
SOURCE: Auto play not working and
GO TO CONTROL PANEL HARDWARE AND SOUND IN THAT YOU HAVE A SMALL CHECK BOX FOR AUTOPLAY PUT A CHECK MARK ND YOU ARE DONE TRY IT OUT
Posted on Oct 22, 2010
Need expansion card software
Driver and info can be found here :
http://www.transcend-info.com/Support/DLCenter/index.asp?LangNo=0&Show=&axn=SRH2&FldNo=7&CatNo=210&ModNo=283&ItemID=TS-PDU3#detail
Jan 15, 2013 | Transcend Usb 3 0 Adapter Pcie For Desktop...
I have a usb 3 expansion card - pci express interface that is not being detected by windows op7
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Dec 01, 2012 | Transcend TS-PDU3 USB 3.0 Expansion Card
Windows can't access my Transcend 16gb SSD Express Card.
did windows ever recognise your transcend 16 gb
this might be a driver related problem
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Oct 18, 2011 | Transcend 16Gb Expresscard Ssd Mlc...
Auto play not working and no removable device icon shown in my computers though the usb is recognised for my transcend hdd
Oct 22, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Problem for Transcend 4GB JetFlash 110 USB 2.0 Flash Drive My pen drive gets heated up and not recognised by computer. what can i do. pl. help
when i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might not work properly).ssuppose if i unplug it i can hear the removing tone.PLs help me to resolve this.........
Aug 24, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 3 pendrive first & second pendrive of transcend & croma is not recognised pny 4 GB pendrive it shows (please insert a drive into F)
try using this software to format the transcend pendrive . use it in XP or Vista www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Aug 14, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to formet transcend usb flash drive.
Insert the flash drive into the usb port of the computer .Once you plugged the device it will be automatically recognised by the operating system .In case of windows operating system you find a new icon in My computer.On the icon of the usb device right click it and there will a option to format it.
Jun 17, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB DEVICE NOT RECOGNIZE
remove the USB drive, reboot your system and plug the drive in...
If system still doesn't recognise the device, update your chipset from your manufacturer's website.
Jun 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb device not recognised.
install the driver for it
search it from
download.com
"can u please rate me free.... for my hint"
thanks in advance
May 17, 2009 | Transcend (589307) Media
Usb pan drive does not recognised by my computer
re-installed the driver after then formate it
Mar 20, 2009 | Microsoft Windows 98 for PC
Transcend TS-RDF8K RDF8 USB 3.0 Flash Card Reader TS-RDF8K Logo
203 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
