Question about Horizon Exercise & Fitness
Belt on my Horizon CST4.6 treadmill stutters or jerks
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
I have a Horizon LS925T treadmill. It seems to jerk. I don't think the belt is slipping, more like the power roller is erratic. It rolls smooth then slows for a second which jerks the belt. Help.
Hi There, This sounds like the control board may be failing. Can you see the control board? Check the 3 larger capacitors for doming or bulging on the tops, which is a sign of high internal heating of the capacitors. This board, 032671 can have issues with these caps. Lubricate deck well, free spin the walking belt by hand to feel for jerky rollers and flat-spots in bearings, if all feels smooth, that controller is most likely at fault or a failing motor with partially shorted windings. Contact jatinah@rocketmail.com for more help if needed.
Mar 24, 2017 | Horizon Exercise & Fitness
Ticking sound on horizon t101 treadmill
If you wish to get some details about treadmill repair; visit the site linked here. in the search tab put the world "ticking" and search.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Horizon Exercise & Fitness
I have a ct83 horizon treadmill, recently there is a bubble in the walking belt that makes noise
Because of the continues usage, It will get spark and make noise. This can be prevent by painting or just put some oil to the engine.
Sep 01, 2016 | Horizon Ct 83 Treadmill Walking Belt
Can you replace the treadmill belt.yourself for an horizon elite t5000
Is the belt damaged to the point that it needs to be replaced? You can adjust the machine to tighten up a loose belt. Instructions on how to do this are in the owner's manual.
Feb 04, 2015 | Horizon Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
LOOKING TO BUY A MAGNETIC KEY WITH BELT CLIP FOR MY HORIZON RTS5.6 TREADMILL
Contact Horizon Fitness at 1-800-244-4192 for customer service.
Parts can also be obtained from the Treadmill Dr., and Fitness Repair Parts..
Dec 15, 2010 | Horizon Safety Magnet Key, Rope/beltclip-
Treadmill says to lube belt, but we aren't sure where that would be?
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Oct 23, 2010 | Horizon Exercise & Fitness
I have a Horizon fitness CST3 and the belt stops running but everything else stays on. Do you know what is cuasing my problem?
How old is your treadmill? Has the deck been lubricated? Do you smell anything odd when the belt stops? Unplug treadmill, remove motor cover and check cables are all connected.
Oct 23, 2010 | Horizon Fitness Merit Fitness 725T...
Exercise & Fitness Logo
42 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
