Question about Frigidaire GLEQ2152ES Electric Dryer
Tumbler makes loud thumping noise when in use
-appears to "drop' at two specific points in the rotation
-drum seems to shift toward the front of the machine
-is there supposed to be a gap in the plastic ring that lines the drum?
    Genius:
  • 2,920 Answers
No it sounds like your motor may be loose...there should be no gap at all
Posted on Jan 20, 2009
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
The tub makes loud thumping noises and seems to drop several times during a wash with very loud thumps and moves the machine.
The shaft that holds the drum sounds like its shifted or gotten bent (sometimes due to moving home, or overloading the machine)
One way to fix this is to open the unit and try to bend the shaft back to an equal kilter, but bending it back won't fix the problem forever, as the metal will now be weakened an d washing machines have fantastic G-force when spinning so weak metal won't keep forever,
but if you have your model number you can always get a replacement shaft and fit it yourself so its like new.
Hope this helps you.
Jan 01, 2010 | Washing Machines
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Drum in Frigidaire GLTF1240AS0 has loud clunking noise
The rear drum support must be replaced.The supporting ball has eaten into the support cup.The belt will have stretched and must be replaced also. You can do the job yourself.
Aug 18, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
LGR7648KQ1 model, dosen't seemd to have in lint in
The thumping noise is a stress crack from poor construction when thr drum was made. I have the exact same problem and found the crack when I removed the top cover by removing the rear upper brace support screws and bracket, then sliding the top dryer panel towards the rear about 3.5" and then lifting it off for complete drum inspection. Rotate the drum by hand and you will see the crack...Mine is at the front, next to the drum seam.... We should all get together and file a class action suit...I'm sure this is a manufacturer fault related problem with this model..
The crack is probably allowing air to bypass the normal air flow through the filter too... Richard
Jun 27, 2009 | Whirlpool Dryers
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Loud Grinding Noise when Tumbler Rotates
Ok, these GE's sometimes have a problem with the front guides bearings going bad, and then the drum starts to eat into the top of the door hole and sides. That is probably what is making your noise. Before you spend a lot of time fixing something that cant be fixed, open the dryer door and look up in each top corner of the opening. Look to be sure the drum hasnt eaten its way through that area. If so, scrap it, because it will eat your clothes badly, and the front panels are to expensive. If not, UNPLUG YOUR MACHINE PLEASE, then standing facing the dryer, open the door, and remove the two screws that are in the top of the door housing area (not the door itself, these would be up by where I told you to look for damage). These screws hold down the top. After removing these screws, lift up on the cabinet top, and pull GENTLY towards you until the top clears the console guide posts in the top rear. After removing the top, inside the cabinet, on either side and at the top, you will see a phillips head screw that holds the front to the cabinet. Remove these screws, and fold the front towards you slowly, removing any wires that may be holding up the swing out (i.e. door switch, light wires, etc., be sure you remember the way the wires reattach). When you look at the top of where the drum rides, you will see a plastic ring with smaller like plastic flat peices that the drum rides in. More than likely, you will have to replace both parts. The ring separates in the center, and is replacable (you should only have to replace the top half). The drum guides are the smaller plastic type guides that just slide in. Reassembly is reverse. Let me know if you need further help. Jim
Nov 22, 2007 | GE DBXR463EBWW Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
209 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
