Question about Minolta CF2001 Copier
Minolta Konica CF 2001
My problem involves a paper being fed into the fusing unit and not exiting properly. It binds up inside the fusing unit and accordions the paper into a wadded mess. Occasionally the paper rolls around the fusing unit. Is this an alignment issue. Is my paper getting wrinkled up before it hits the fusing unit, then when it is on its way out of the fusing unit it binds up between the oil coating unit? I use standard paper. I live in New Mexico so humidity is not a real big issue. We rarely see 50% humidity with any regularity. The paper is stored flat in a drawer still in the wrapping paper. Please advise.
Firydont boot wath can i do
Posted on Mar 12, 2008
The copier may need both an oil coating unit and oil supply unit. We use CF910 fuser oil and re-coat both units. This will band aid the problem temporarily and will also tell you if the problem is lack of oil.
Posted on Oct 11, 2007
Sounds like it's not the paper. It could be a feed path problem (the path the paper feeds thru). About the only solution, aside from you tearing it apart, is to have a tech look at it.
Posted on Jun 28, 2007
SOURCE:
My Bizhub C203 indicates that there is a paper jam at the exit. but i had checked and there is no jam. I also had replaced the fuser unit thinking it will fix the problem but the problem is still the same...
I have had in the past on these models that when paper is being fed to the exit section the exit rollers are not spinning so paper doesnt get pushed through to the output tray. If this is the case then you will need to replace the exit roller drive motor and possible the PRCB too as sometimes when the motor becomes faulty it knocks out the PRCB ICP chip on the board.
Feb 13, 2015 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub C353 wrinkles all papers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Nov 07, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Konica minolta c451 code 2257
Sir/Mam there is cleaning motor for one of the rollers in the fusing unit the very hot part on the right side of the machine is there anything like a transprancies or paper wrapped around the fusing unit roller. Recommended that you get a tech out to look at it remove the fusing unit and look it over. Do not use the machine you burn out that motor it will cost more to repair worse case you burn out the main control board 1000 dollars. Motor is inside the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
ERROR CODE C2163
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Sep 23, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
Toner not fusing on minolta bizhub c250 properly, what is the cause
The fuser unit is faulty. The fuser heats the toner so it melts the toner onto the paper.
Nov 16, 2012 | Konica Minolta bizhub C250 All-In-One...
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook.
Apr 02, 2012 | Konica Minolta Konica Bizhub C353 Drum...
Konica minolta 7416MFG saying paper jam but i removed sll the papers without tearing
the door or cover is not properly closed or it may still have piece of paper inside it.
May 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Where can I get the Imaging Unit Cleaning Papers for my Konica CF2001
Please describe your problems.Image cleaning papers not exist in Minolta CF 2001.
Apr 27, 2010 | Minolta CF2001 Copier
How to specify the appropriate media type in the printer driver with the Konica Minolta 2400W
Go to printer properties -> Printing Preference -> Paper -> Media Type
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 13, 2009 | Konica Minolta magicolor 2400 Laser...
108 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
