Wep key centurylink router - Computers & Internet
4 Suggested Answers
dante777
  • 623 Answers
SOURCE: Where can I find the WEP key on this router? Thanks!
If you don't have the manual, you can download it here.
Look at page 11 onwards.
1. Log on to your router:
  • type http://192.168.1.1 in the URL bar of your browser
  • default username and password: admin/admin
2. Go to Wireless -> Interface and you will find the WEP key there.
Just a note on security:
You should try NOT to use WEP, since it is not secure anymore.(Just google "hack WEP" and you will get over a million results...)
If your wireless cards a capable, try to use WPA2/PSK, which is the best protocol and the strongest encryption.
Tip: Use a random string of characters (like H98yh&VOrh... you get the idea). Save the Network key in a text document and copy it to a USB stick, so you don't have to enter it manually into your wireless computer.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 29, 2009
devverma143
  • 163 Answers
SOURCE: How do I find or change my wep key? Belkin router
For this first of all u need to know the ip address of the wireless router.and its username & password.. Once u know the all this u will enter the wireless router configuration wizard.. In it go to security tab , there u can see security type and then change its wep key
Posted on May 06, 2010
  • 825 Answers
SOURCE: I just purchased a Netgear
WEP code will be 10 digits only...you need to type all the 10 digits together (without any spaces)... Try disabling netgear utility and use your default windows utility...It is not the problem with netgear....
Posted on Aug 07, 2010
I need to know what the wep key is
Jun 10, 2011 | Linksys WRT120N Router
What is the wep key
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
  • 1A648C9FE2
  • 99D767BAC38EA23B0C0176D15
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other. The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
Feb 15, 2011 | Linksys E3000 Wireless Router
I have CenturyLink. I cannot get the Belkin router to work. What to do?
IF THE MODEM GIVEN BY CENTURY LINK is 660 Series then the IP Address of the Modem and Router Will be the same
So before starting the troubleshooting ... Disconnect the centurylink Modem from the Belkin
Step 1 : Connect One of your computer to the belkin ( to any one of the 4 grey ports ) with an ethernet (CAT 5 ) Cable
Step 2 : Open internet explorer
Step 3 : On the address bar type http://192.168.2.1 and press enter
Step 4 : If you are at the belkin Router Setup utility ..
Step 5 : On the Left under LAN Setup click LAN Settings
Step 6 : Leave the Password blank and click submit
Step 7 : Change the IP Address to 192.168.3.1
Step 8 : Click apply changes
Step 9 : Connect the Modem - Router ( to the yellow slot )
Step 10 : Check the color of the light in the Router
Step 11 : If it is solid green .. Check if you have internet
SETTING UP A WIRELESS NETWORK
Even though The router comes with a Pre-Set Wireless network many people wont like to use it
if you like to setup a connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 26, 2010 | Belkin Wireless Surf Router (F7D2301)
I just purchased a Netgear N300 wireless usb adapter. After installing the netgear software it ask for the WEP code off of the Centurylink provided Zyxel 660hw. The problem is the WEP code on the bottom of...
Aug 07, 2010 | Zyxel Prestige 600WH Wireless Router...
I received a 660R modem from CenturyLink. It works fine when connected to a single computer but when I connect my Belkin Pre-N v1000 wireless router, I no longer have an internet connection. CenturyLink...
Please see the attached manual for the centurylink router and modem. There is a section discussing RIP direction. Normally it is set to none because it assumes the centurylink unit is your router. Change that setting to both and then reconnect your router and see what happens.
The link for the manual is:
ftp://ftp.zyxel.com/P-660R-61/user_guide/P-660R-61_3-40.pdf
If this works, please indicate so with your response. If not, then provide more information about what you have tried and how you are trying to set everything up.
Good Luck.
Feb 06, 2010 | Computers & Internet
I need wep key westell model 327w
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
That is the only way. Thank you!
Nov 02, 2009 | Westell Wirespeed VersaLink...
Can't find security key
the wep/security key on 2 wire modems is located below the serial number label on the side of the modem.
Sep 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
