Question about Marantz Audio Players & Recorders
RC010SR remote partially works
It worked fine last night.this am the remote would not work.. There was a bit do corrosion on battery terminal. They were cleaned and then new batteries were inserted. Now only on off and volume down works. The red light doesnotevencomeonfor anything else.
SOURCE: Volume not working on remote
Just get a universal remote like i did but i also had another technics remote from another unit.
Posted on Oct 01, 2007
SOURCE: Remote Volume Control Not Working
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Posted on Mar 13, 2008
COWBOYPOL_06
  • 13 Answers
SOURCE: remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Posted on Oct 21, 2008
  • 3940 Answers
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Posted on Feb 01, 2009
SOURCE: remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Posted on Feb 20, 2009
I need to know if the remote is defective or if it is the TV.
early remotes work by infra red light ( small bulb or opening at the front of the remote )
turn on the camera of your cell phone -ipad and aim the remote at the camera lens
if you see a white spot on the screen when you press the remote button , it is working
Nov 28, 2015 | Televison & Video
Remote doesn't work
It may be that the battery terminals in the remote are not making good contact with the batteries. Make sure the terminals do not have corrosion on them. If there is any corrosion, especially on the flat terminals ( where the positive side of the battery goes) , clean the terminal(s) with a little rubbing alcohol on a cotton swab. The terminals should be shinny. If they are not, first scrape them with a small flat screw driver or anything that will fit, a small knife tip, etc. Then clean with cotton swab. Also make sure the terminals are making good contact with the batteries. The batteries should fit tight. Again, with anything that will fit, try to gently pry the flat terminals out a bit. Hope this works for you!!!!!!!!!!
Mar 26, 2014 | LG AN-MR300Q Remote Control AKB73597001
Batteries don't last
Check the battery connections to the wire ends for corrosion and tightness. Take the wires off the battery and remove any obvious corrosion. Take a knife blade and make the wire end shine and the same for the battery terminals. Reassemble the wires to the battery and tighten.
Jan 12, 2014 | Pride Go Chair Travel Power Chair
AH59-02402A REMOTE, WAS WORKING FINE LAST NIGHT AND EVEN THOUGH THE LIGHTS BLINKED ON IT I TRIED NEW BATTERIES STILL WILL NOT CONTROL BOX???
If it show it was doing updates, Thats probably why it wouldn,t work .Once it has updated ,IT will (Probaly) Work (Again)
Nov 07, 2012 | Televison & Video
My phone is dead. I charged it last night and it
Could be a loose connection by the battery terminals give it a clean, if nothing works you should try and get a new charger or battery or both. Hopefully this helps.
Sep 15, 2009 | Samsung Cell Phones
My RCA HDTV remote won't work with the regular tv. It was working fine last night until i pressed the tv botton and the volume button.
One thing you can try is to take the batteries out of the remote and then press every button on the remote, then replace the batteries. I have used this technique several times and it works. If that doesn't help try leaving the batteries out over night, this may reset the remote.
I hope this helps.
asnowman
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
Remote won't work
Feb 18, 2009 | Samsung TV Remote Control
My remote wont work
Make sure there isn't corrosion on the battery terminals. Try cleaning the battery terminals. Batteries left for a long time in one device will leak and corrode the terminals so even with new batteries the remote might not work. New batteries usually help too LOL !! Good Luck!
barneyluc
Oct 03, 2008 | Televison & Video
RCA RS2052 Bookshelf System
Have you tried cleaning the sensor on your stereo, and also the transmitter on the front of your remote? Otherwise check the battery terminals in the remote for corrosion to make sure the batteries havent leaked.
Nov 27, 2007 | Thomson RCA Bookshelf System with 128 MB...
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
