Question about Toshiba Satellite M35X-S149 Notebook
Laptop never charges
I am having a problem with my laptop..I am charging it but it b=never charges so when i start it it shut off and never turned on.But the orange bulb is always on even though I put it on charging for whole night
You're double posting.
Posted on Jun 28, 2007
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
It goes dark, shuts off constantly. Battery meter isn't showing charging.
Unplug the battery and plug in the AC power plug into the laptop;
Does the laptop start up and stay on?
If yes,
Then put the battery in WHILE IT IS ON; See if it starts charging.
If it does not; You have a bad battery and need to replace it.
If it does start charging here's what happend;
Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all.
The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in.
By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up.
If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue.
Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
Sep 30, 2013 | Toshiba Satellite L655-S5101 Laptop
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 17, 2011 | Computers & Internet
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
New Aspire One laptop battery is not holding a charge. It goes dead sitting in case turned off.
The baterry does not get charged if the computer has been shut-down. It will only charge from your AC adapter only after you have simply started your laptop and let it be idle for a couple of hours. Its advisable to use your AC power adapter as much as possible when using...........sodeep
Mar 19, 2009 | Acer Aspire One PC Notebook
Won't turn on.
Try starting it up without the battery. Batteries can pickup a dead short which will cause a laptop not to start even though they show a full charge.
Jun 11, 2008 | MetroBook VL Plus C-266 Notebook
My Toshiba Satellie P15-S470 turned off by itself and I can not mak it to run.
Sir:
Is your laptop connected to a power source? If not it needs to be recharged...
Check also the battery of your laptop, it might be dead already... meaning even if it is charging the battery doesn't charge anymore... it may need replacement.
To check the battery... remove it from the laptop and find a flat button to check if the battery is charged, or half charge, or none at all. If below half then the battery needs to be replaced.
Jan 23, 2008 | Toshiba Satellite P15-S470 PC Notebook
Toshiba Satellite M35X-S149 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
