Question about RCA 27F650T 27" TV
Digital programming for rca j26L637 I can only get the local channels in digital, how can I get the rest (ie cable channels)
  • carlos35023 Mar 09, 2009
    I can not program additional channels to the TV, for cable service.
I have a similar tv. Its specs. aren't clear about that point. It can get OTA digital via antenna, but my component connectors show no picture when hooked up. I guess if your cable co. sends digital signal it should work in the digital antenna input. Same one as for the OTA signals, and they claim no cable box is required.
I am awaiting any help and it may also apply to your situation.
Take care, breezelow
Posted on Jun 22, 2009
How do I program my RCA LED48G45RQ HDMI to digital channels
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Dec 09, 2014 | RCA Televison & Video
Why won't the cable channels scan
Your TV will not get digital channels if you do not program the digital stations to your TV. You can program the digital channels by running a digital channel scan. The entire process is completed from your remote control and does not require any tools. This task only takes a couple of minutes to complete, and then you will be able to enjoy digital channels on your TV
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Oct 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA 27F650T 27" TV Logo
224 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
