Question about Brother Office Equipment & Supplies
Brother HL 2240D toner light stays on after replacing it with the new toner
SOURCE: BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Oct 24, 2007
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
SOURCE: Toner
Trick the thing. Put a piece of black electrical tape on the "eye". (Take cartridge out, on right side there's a small clear hole). Worked for me!
Posted on Oct 22, 2008
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Feb 01, 2009
  • 10 Answers
SOURCE: Brother HL-5140, Status light is red and toner
It is very hard to find the reset instructions on the Brother Solutions site.
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Posted on Apr 21, 2009
Brother Printer HL-2240D makes an encouraging noise for a moment, but then dies and no paper appears.
Are you sure you are using the correct driver for your OS? Did you print out a test page to make sure all is fine with printer?
Sep 11, 2017 | Brother Office Equipment & Supplies
How to stop and cancel printing on brother Hl-2240d printer on a Mac Pro computer
Most printers can be stopped by going to your control panel and selecting printer and then find the command that cancels the printing job. Try this teaching video:
https://www.youtube.com/watch?v=YXIM_17IIl0
Feb 28, 2015 | Brother Hl2240d - Hl-2240d Laser Printer...
Printer problem
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. We need to reset this now!
4.Open the front cover of the printer
5.Press and hold down Go button for about 4 seconds until all the LEDs light up.
6.Once all 4 LEDs are lit, release the Go button
7.Close the front cover.
8.Your drum is now reset.
Jul 18, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Hl 2270 won't stop printing
I would guess you were trying to print a spread sheet or similar. It has nothing to do with the reset gear on the cartridge. You need to open your printers folder on the computer, open the print queue for the printer, and cancel all documents waiting to be printed. That may take more than one try. When you are ready to print again, be sure you know what is to be printed before committing.
Apr 21, 2014 | Brother Reset Gear for TN-450 TN450 TN420...
Brother hl2270dw toner light stays on
Have you tried resetting it? I can't remember all the steps, I see some of the other comments have them but just to be sure you didn't miss anything I suggest you download the manual and go step-by-step. You can find one here - Brother HL-2270DW manual
Mar 24, 2012 | Brother HL Office Equipment & Supplies
Hi when I turn on the Brother HL 2150N the yellow toner light stays on & I can't print
Silly question I know, is the toner new install if not could have run out.?
Would you by chance have a replacement to insert, to see if problem perstists?
May 26, 2011 | Brother HL-2150N Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
