Question about Dell jt782 - Fan Assy Cpu Cooling, Optiplex 745, Usff
Dell optiplex 745 rear fan failure
My employer has multiple 745s and the only thing wrong with them is "rear fan failure". Some rear fans work intermittently, but all need to be repaired. I believe the problem is with the fan's interface to the motherboard malfunctioning. I read about a fix where you could remove the interface from its socket on the motherboard and bridge the wiring to the interface supplying power and diagnostic info to the front fan, however I cannot find this post again to save my life. Does anyone know which function is associated with which color wire as I believe this is a proprietary wiring scheme? Or even better, does anyone know anything about the previous post I just referred to?
BigZ1981
  • 24 Answers
SOURCE: Fan Noise on Dell Dimension 8100
All computer fans have a general design.  The name in front of "fan" really refers to the designation.  You'll see case fan, processor fan, CPU fan, cooling fan, etc.  In the case of CPU/Processor fan, some are sold with heatsinks (the metal block sitting on top of your CPU).
The first thing you want to do is make sure the fan is clean.  Chances are dust buildup is causing the excess noise.
If that's not the case and you're looking to replace the fan, then you first need to find out the size of the fan. General sizes(diameter X width in mm) are listed on this page:
http://www.svc.com/case-fans.html
Generally, you're looking for something that will match the size of what you're replacing & push enough air at a reasonable noise level to cool the heatsink/CPU.  You want to stay in the area of 30dBA max for noise.  You also want to see if it has a 3-pin or 4-pin connection.
For example, if you have an 80mm fan, I would suggest something like this:
http://www.svc.com/saf-b82-19.html
It's pretty quiet with good airflow.  Also, it has a 3-pin connection, but includes an adapter for a 4-pin connection.
Z
Posted on Oct 27, 2007
kornho
  • 781 Answers
SOURCE: Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Posted on Sep 25, 2008
  • 998 Answers
SOURCE: Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 13, 2008
APremkumar
  • 564 Answers
SOURCE: Dell Dimension 5100 No Power No lights
Hi Eric,
Don't Worry we can fix this this problem.
This seems to be no power issue.
Just mail your email address and number to apremkuma@gmail.com
Thanks, Prem
Posted on Mar 08, 2009
  • 16 Answers
SOURCE: Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Posted on Jun 11, 2009
AEG Competence B3101-4m oven not working on fan setting. Fan operates but no heat. Also intermittent problem on full grill setting. Any ideas?
ISOLATE MAINS POWER BEFORE OPENING ANY PANEL
Several possibilites come to mind.
first Has this AEG two fans if yes , it has a top and back fan, the element on the back fan sounds like its either a bad connection or blown needs further investigation, the intermittent grill possibly a thermistat, of poor contact on a connection again. Rear and top panel access, you may have to remove the top fan.
Hope this has been helpful
John
May 31, 2011 | Electrolux Ovens
Well i have a problem the fridge is working 100% but our freezer is not working right it is cold at bottom half but it is not working at top half like i put ice thing in it the water fast freeze tomoro...
If I read the manual right the red light indicator your seeing is the exlamation point above the fast freeze button. This is telling you that the freezer compartment temp is to high.
There can be multiple reasons for this:
1. Evaporator fan not running (Check fan by depressing door closed plunger for the light switch) The fan should be on and light off.
2. An unseen block of ice over the evaporator coils due to an automatic defrosting probelm. If you can determine that there really is ice on the evaporator coils, perform the manual defrost procedures I described in my initial response. If after doing this manual defrost things return to normal for a few days and then you see the high temp indicator again there is for sure and automatic defrosting problem.
3. Automatic Defrost Problem (Causes)
a. Defrost control failure
b. Defrost control heating element failure
c. Temp sensor failure or Bi-metal 60 Deg F thermostat failure
4. Condenser fan not running in the borrom rear of the unit. (Check to see that the fan is running by removing the fiberboard rear cover.)
5. Condenser coils blocked with lint (Check the coils when you inspect the condensor fan for operation.) Clean both the coils and the fan.
6. Thermistor failure (measures temp and has a resistive output) in the freezer.
7. Compressor not running (Causes)
a. PTC relay
b. Run capacitor
c. Conpressor failure
8. Compressor running but not cooling
Check to see that one of the copper lines line is hot to the touch. If it is not hot the causes can be low freon level, clogged freon drier, damaged capillary tube.
These are all the things that can cause your current symptom.
Thanks for choosing FixYa,
Kelly
Mar 20, 2011 | Refrigerators
My fan is Intermittently offf and on idk why is there something wrong in the fan or the laptop
Dear zidane_is_th
No there is nothing wrong with it. It is reacting to the heat build up in your PC. When it senses the temperature rise it will kick the fans on to help it cool down.
Just be sure and keep your vents from being covered so as not to hinder the fans when it needs to cool down. Overheating is the No.1 cause of failure in Laptops.
Like random shutdowns.
Hope this helps if it did just click the thumbs up
Feb 10, 2011 | Toshiba (K000016310) Cooling Fan
When I turn on the fan for the cabin, it does not start blowing air as it should. I am guessing it is an issue with the fan / blower mechanism. Wiring could be the primary issue because sometimes the fan...
If the fan operates intermittently, but normally when running, it is less likely that the fan motor is the problem. More likely it is a failure in the power supply to the fan motor. If the fan motor was faulty it is much more likely to cease operation totally rather than to operate intermittently as you say it has been doing.
Without physically checking the operation myself it is hard to diagnose. However, there are at least 2 areas for checking:
1. The fan switching mechanism. Is your fan switch faulty and cutting power flow? As the problem is intermittent operate the switch a number of times to see if the symptoms repeat at a time the fan is operating for you.
2. The wiring. There could be a dodgy connection in the wiring to/from the fan motor which is intermittently cutting power flow to the fan motor.
This will need to be carefully checked.
I would suggest you also contact your local toyota service department and talk to one of the experienced people there. Just suggest you are going to bring the vehicle in for service. <More often than not it is likely a number of owners will have come in with exactly the same problem as yours in which event they will be able to tell you what they diagnosed in previous cases. If you cannot get any useful info then contact another dealer.
Dec 05, 2009 | 2006 Toyota Tundra
1997 Dodge Intrepid / 3.5 L - failure of fans, airbag, ac, etc.
have seen ignition switch cause all of these symptoms..also make sure connections at switch are clean and secure..
Mar 19, 2009 | 1997 Dodge Intrepid
Fan failure
chances are it's the one large fan in the rear of the unit. That's the most common to fail. Easy to do yourself. A $30 part and 20 minutes total to do, unscrewing with a Philips screwdriver, replacing the fan, and putting it back together...
Part is:
Motor dc sff21c/c-np
Aug 17, 2008 | Sony KDS-R50XBR1 50" HDTV
I am geeting error code 48 on my phaser 7750dn
that is a fan failure code, Either the Fuser fan ( most likely) behind the back cover near the front.Low voltage power supply fan or rear cover fan is not operating.
Most of the time it is the fuser fan that is not running or even if its running slow it will give you that error code.
Here are the notes
Problem:
    Fan Failure Message (Code / Error 48)
Cause:
    The machine logic detected a failure of the Fuser fan, LVPS fan or rear fan.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. Insure there is adequate ventilation around printer. Refer to Section 1 of Service Manual for required clearances.
  2. Follow the procedure in Chapter 3 for this error.
  3. This problem can be very intermittent. Fans can work in diagnostics and fail in the middle of large print jobs. If unable to duplicate problem replace all 3 fans.
  4. Use service diagnostics to verify the Fuser, LVPS, and ROS fans. These fans have a third wire which provides feedback to the Engine Board.
  5. Visually check each or these fans for a build up of dust or toner.
  6. There is a correction to this procedure in the Service Manual. The fans that can cause this error are the Fuser, LVPS, and ROS(laser fan). Not the Rear fan. The rear and bottom (developer) fans are not monitored by the system and won't generate this error.
Parts that may resolve this issue are:
  • FAN ASSEMBLY, FUSER (63%)
  • FAN ASSY; LOW VOLTAGE POWER SUPPLY (45%)
  • FAN REAR ASSEMBLY (Laser Fan) (25%)
May 05, 2008 | Office Equipment & Supplies
Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
Dell jt782 - Fan Assy Cpu Cooling, Optiplex 745, Usff Logo
2,666 people viewed this question
Alun Cox
